orange wire has no power
Old 03-29-2015, 01:27 PM
ChefRex's Avatar
ChefRex
ChefRex is offline
Orange and white is switched power, there is a single wire, red I believe, gray connector in front of the battery that is direct to the battery.
72172-?, 98 I think but could be wrong on the dash number is the proper terminal.
Old 03-29-2015, 02:41 PM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Originally Posted by Gannicus
I misunderstood what he was asking. I thought he was simply trying to wire his HU. NHRider if you answered as many questions as I do on a daily basis your advice might get a little faulty as well. For the record I don't give out faulty advice. But then again nobody is perfect. . .
Sorry...I wasn't referring to you in particular.
Quoted:
most people tell me that I can use the orange wire with a white stripe under the seat running back towards the tail lights
Didn't mean to cause any problems.
Old 03-29-2015, 03:55 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Quoted:
No worries brother. My bad. . I guess I got up on the wrong side of the bed today. Hope you're having a better day than I'm having!
Old 03-30-2015, 12:06 PM
star2nv's Avatar
star2nv
star2nv is offline
every one of you guys has been a big help I think I've been going about this the wrong way coming off my head unit there is a red wire a yellow wire black wire which is a coarse ground and then the blue wire which of course is power antenna or Amp. does this sound like the yellow wire needs to go to the battery because it controls the clock in the memory it have to have constant power the red wire needs to go to a switchable hot lead which will control the on and off if this is the case what I am doing is this exact opposite I had red going to the battery yellow wire going to a switchable power source so when I would turn the key off the switchable power source would shut off and I would lose my memory and my clock does this sound about right to you Guys am I on the right track now
Old 03-30-2015, 12:58 PM
ALUCARD19's Avatar
ALUCARD19
ALUCARD19 is offline
That is correct, on my Kenwood HU the red wire is the switched hot, only on when in run or acc position, and the yellow wire is for the memory function of the radio always hot.
Old 03-30-2015, 01:38 PM
nhrider1's Avatar
nhrider1
nhrider1 is offline
That is correct...Yellow to the battery. It should only draw a few milliamps.
Red to Switched Power.
You had them reversed.
Old 03-30-2015, 03:42 PM
star2nv's Avatar
star2nv
star2nv is offline
Yes I had them reversed. okay one more question so does the 8 gauge wire hot wire coming off the amp go straight to the battery or does it go to a switched power source Also?
Old 03-30-2015, 06:39 PM
ALUCARD19's Avatar
ALUCARD19
Yes right to the battery but put an inline 30 amp fuse within about 6 inches of the battery and make sure you can access it if need be.
wildrooster
08-23-2020 12:38 PM
DavesEagle
Electrical/Lighting/Alarm
12-16-2018 10:29 AM
knitski
Audio Systems
05-24-2017 12:21 AM
TedMan
05-25-2011 08:15 AM
Smitty0128
06-01-2008 07:57 PM
Quick Reply: orange wire has no power
