biketronics question
Old Mar 30, 2015 | 10:06 AM
MvpHD's Avatar
MvpHD
Default biketronics question
I think I'm ready to make my purchase. Thinking about going with the biketronics setup. Just going to run the fairing and tourpack speakers on my 2010 ultra classic. So do I go with the 4 channel amp or would the BT 2180 be good enough? Will I lose FM signal with either one? Will the fader control still work? This is good chunk of $$ and want to make sure I will be completely satisfied. Thanks in advance.
Old Mar 30, 2015 | 10:31 AM
haze324's Avatar
haze324
1. 2180 can power 4 speakers. No more.
2. If you ever want more than 4 speakers you need the 4180 (or a second amp at that point). Neither amp affects FM reception.
3. With the 2180 powering 4 speakers you do lose front/back fade control.
Old Mar 30, 2015 | 10:22 PM
ridedaddy's Avatar
ridedaddy
What speakers will you be using? That's important concidering we would need to know how much power they can handle.
It's been awhile since I have played with the factory head unit, I can't remember if it has a balance left to right? If it does then you could run the front speakers off of the left channel and the tears off the right channel to achieve a fade control. However you may loose the stereo effect.
My vote would be go for the 4180. Assuming your going to use speakers that can handle the power. With that said the 2180 would do a good job also but your fade feature may suffer.
Old Mar 30, 2015 | 10:56 PM
Crimson's Avatar
Crimson
No L/R control on stock HU.. I concur on the 4180 - If you can afford it, buy it.. because you will end up buying it at some point if you settle for something less..
Old Mar 31, 2015 | 08:37 AM
MvpHD's Avatar
MvpHD
Placed my order with Bill at Biketronics yesterday. Decided to go with the 4180 amp, 7.1 fairing speakers, alpine tourpack speakers, and the Kenwood head unit. Can't wait to get this hooked up !
bazwp
Audio Systems
Sep 13, 2018 12:21 AM
fournierrandy
Audio Systems
37
Dec 5, 2015 11:17 AM
Brancajd
Jun 28, 2012 09:04 PM
blockzilla
Mar 3, 2012 04:49 PM
xtremechopper
Nov 7, 2009 06:04 AM
