It's better to have too much than not enough. You don't want to run your amp at full capacity all the time (hard on the amp and causes speakers to distort and get muddy real quick)
Short answer: no your BT 2180 will not destroy speakers, AS LONG as it is tuned properly.
Now there will be some guy's who can chime in that will have experience with that amp and can give you some more info.
You cant tune or adjust a 2180. However, I believe those amps are designed to auto adjust output based on speaker load so should be fine with those speakers.
Ahh shix, I was wondering that after I posted. Though I remembered no adjustments on them. Give Biketronics a call
You can actually run any of those speakers with the 4180 with good results and I'm sure they all have been (probably by Gan)! The last 2 speakers would be the better choices IMO,
