radio help needed
Old Mar 31, 2015 | 10:04 PM
rtreftz's Avatar
rtreftz
Default radio help needed
My Roadglide lost a battery connection and I tightened the connections and radio has no sound. It has a amp but the fuse is hooked up and fuse is good. Did the self diagnosis and nothing out of normal, just open front speaker as is should when amp is installed.
Old Mar 31, 2015 | 10:07 PM
rtreftz's Avatar
rtreftz
Old Apr 1, 2015 | 06:32 AM
z71_fourwheelin's Avatar
z71_fourwheelin
Check the fuse where you get your remote turn on wire hooked up.
Old Apr 1, 2015 | 03:10 PM
rtreftz's Avatar
rtreftz
Fuse and wire are good. 12v going up to dash.
Old Apr 1, 2015 | 04:00 PM
z71_fourwheelin
What amp are you using? when you turn the ignition on do any lights on top of the amp light up?
Old Apr 1, 2015 | 06:11 PM
Gannicus's Avatar
Gannicus
I've seen so many of the stock HU's just stop working for no apparent reason it's very hard to diagnose. If you have checked all your wiring, fuses and connections. I'd almost be
willing to bet it's time to pull it out and send it to Iron Cross. I'd double check all my connections and unplug the radio from the harness and plug it back in. If it's still dead in the water call IC for suggestions. Very reliable Very reputable company with excellent customer service.
Gannicus's Avatar
Gannicus
Sorry for the double post: My 4G appears to be running at 2G today.
Old Apr 1, 2015 | 09:42 PM
Little Mike's Avatar
Little Mike
If you get another one of those 2G phones and hook them up in series you'll be back to 4G.
Old Apr 2, 2015 | 12:06 AM
Gannicus's Avatar
Gannicus
Yeah - I let my wife talk me into the Iphone 6+ My samsung android note 3 was nice. But I get better reception out in the country with the Iphone.
Old Apr 2, 2015 | 06:28 AM
ALUCARD19's Avatar
ALUCARD19
Stay on topic sheep this is not a phone forum.
