PBR current draw when off
Old Apr 23, 2015 | 07:01 PM
liquidr1's Avatar
liquidr1
Default PBR current draw when off
Anyone know how much current the RF PBR300x2 draws even when its off?
Pretty sure my battery is bad as I cant get it to charge past 10.5-11 volts even with a battery charger ( not a tender). Already ordered a new battery from battery mart.
just curious how much current these draw when they are off.
Old Apr 23, 2015 | 10:50 PM
onewheat's Avatar
onewheat
An amp shouldn't draw anything when it is off - as in 0.00 volts. If it does, there is a problem.
Old Apr 24, 2015 | 08:21 AM
tsigwing's Avatar
tsigwing
Close. O.OO Amps.
Old Apr 24, 2015 | 06:23 PM
just plain john's Avatar
just plain john
The amp turns on when it gets a signal voltage, which is supposed to come from the radio. Could it be getting that signal somewhere else, like a constant hot?
Old Apr 24, 2015 | 07:15 PM
liquidr1's Avatar
liquidr1
Well, I was curious if there is a circuit in the amp that may use some power to monitor when signal is received to fully power on.
Old Apr 25, 2015 | 08:01 AM
just plain john
Not to my knowledge. My aftermarket radio has a remote turn on wire from the head unit to a terminal on the amp. Radio comes on, turns the amp on. The amp is off otherwise and draws no current while it's off.
Old Apr 25, 2015 | 04:27 PM
Liquidoxygen's Avatar
Liquidoxygen
This has me wondering if the 12 volt plug has constant power? I used it as my remote turn on source.
Old Apr 25, 2015 | 06:52 PM
just plain john
No, I think that's switched power. The lighter doesn't work unless the ignition switch is on.
MyFavRk
Jun 22, 2019 07:01 PM
Jonny Rotten
General Topics/Tech Tips
Apr 12, 2019 12:49 PM
my74ls4
Feb 5, 2016 10:06 PM
Von Scott
Aug 7, 2013 05:11 AM
Quadancer
May 7, 2013 07:54 AM
