Volume control switch
Old Aug 9, 2016 | 09:53 PM
Bertk's Avatar
Bertk
Originally Posted by SBates08
^^^^^Fixed link^^^^^
Link error on PC. "Mobile View Not Available"
Old Aug 10, 2016 | 10:06 AM
jefla's Avatar
jefla
Originally Posted by Bertk
Boardtracker HD has it for $49+ shipping
Thanks. Already had ordered from St Charles, paying $62.
I read on another forum that the "only" proper way to install these switches is to run the provided line through the bars to the post-bar connector, and that the common practice of splicing inside the the bar-end controls housing leads to trouble. It would be great to hear this subforum's thoughts on that assertion.
Old Aug 10, 2016 | 02:14 PM
Bertk's Avatar
Bertk
I haven't replaced this part before and don't know exactly what comes in the box. As far as I know the stock wires are run on the outside of the bars.
Here are the 2008 service manual instructions for replacing the control switches.
Attached Thumbnails Volume control switch-118.jpg   Volume control switch-119.jpg   Volume control switch-120.jpg   Volume control switch-121.jpg   Volume control switch-122.jpg
Old Aug 10, 2016 | 06:32 PM
yooperhog's Avatar
yooperhog
kit should contain the switch and 4 internally connected wire already attached wires should be long enuf to reach the molex type plug under the fairing. either you pop the plug apart and put new pins on the ends of your new wires or make a solder connection a few inches from connector. the wires on your new swich will be color coded to match existing wires. if you havent worked with the duetch pins and popping apart the connecter ends, you may want to simply solder the wires with some good quality shrink wrap
just my opinion
Old Aug 10, 2016 | 08:49 PM
TwoBlue02's Avatar
TwoBlue02
I have to say out of all the things I have done to my bike putting the chrome covers on was probably the hardest. Small spaces and small screws.
Take pictures of everything while you take them apart. Just sayin'.....
Old Aug 10, 2016 | 09:02 PM
Bertk's Avatar
Bertk
On the 2008 the controls use Molex plugs under the fairing.
Attached Thumbnails Volume control switch-a-30.jpg   Volume control switch-a-31.jpg   Volume control switch-connector-locations.jpg   Volume control switch-connectors.jpg   Volume control switch-connectors-2.jpg
Old Aug 10, 2016 | 09:21 PM
murph's Avatar
murph
You will be amazed how useful a paperclip is.... just saying.
Old Aug 10, 2016 | 09:51 PM
Bertk's Avatar
Bertk
I purchased one of these years ago after going the paperclip route. Worth every penny.
VintageWest
May 26, 2019 06:43 PM
Susan29
Electrical/Lighting/Alarm
Jul 16, 2018 03:04 PM
hammick
Sep 20, 2013 08:56 PM
ULTRA Gramps
Touring Parts
Aug 22, 2011 01:12 PM
aviscomi
Jan 21, 2010 05:17 PM
