Moto 600.4 Instal Help
Old Jul 14, 2015 | 02:15 PM
Woodys03's Avatar
Woodys03
So I have the amp now. As I understand from the drawing above is that the wires on the plug in on the left is coming from the radio and the block on the right is going out to the speakers?
Old Jul 14, 2015 | 06:54 PM
acchd's Avatar
acchd
Yes the speaker output wires exiting the HU/Radio you'll remove at the stock speakers and connect to speaker level input plug following the respective color coded wires for the proper channels. Althougth I didn't need it now I emailed Arc for a speaker level input plug and just received it in mail today. They've also sent me spare screws for top cover plate no charge there customer service is fantastic!
Old Jul 14, 2015 | 09:51 PM
Woodys03's Avatar
Woodys03
Do you have a picture by any chance. I'm a visual learner, any thing else and I'm pretty much retarded.
Old Jul 15, 2015 | 12:32 PM
acchd's Avatar
acchd
I don't other than whats in manual. Brad Ott in Arc Audio Tech Support may have something else. Shoot Brad a email Brad@arcaudio.com
Old Jul 15, 2015 | 10:36 PM
Denis1227's Avatar
Denis1227
What amp fuse did you use?
Old Jul 15, 2015 | 10:38 PM
Woodys03's Avatar
Woodys03
I'm running a 30amp maxi fuse in line if that's what you're asking.
Old Jul 15, 2015 | 10:59 PM
Denis1227's Avatar
Denis1227
Yes, that's what I was asking. I just got mine installed tonight, and was rolling down the highway, and lost everything. Came home, pulled the seat, and my 30AMP fuse was blown. Don't know if it was because I had it up to loud? Had been messing with the tuning since last night and had no problems. I see on ARCS page that their ANL fuse holder comes with a 200 AMP fuse. I am calling them tomorrow to see what they recommend.
Other than that issue, this amp ROCKS. I am running the Focal 165 KRX2... What a system...
Old Jul 15, 2015 | 11:14 PM
haze324's Avatar
haze324
30 should be fine. Check your power cable make sure you don't have a short anywhere.
Old Jul 15, 2015 | 11:20 PM
Denis1227's Avatar
Denis1227
If I had a short, wouldn't it blow right away?
Old Jul 15, 2015 | 11:22 PM
haze324's Avatar
haze324
Could happen from vibrations while you were riding.
