speaker issue
Old Aug 30, 2015 | 10:41 AM
haze324's Avatar
haze324
Originally Posted by scumBAGGER
yep its run to the battery and per BT I added one from back radio to neck...
going to run all new power\ground etc after Labor day weekend..
I did not mention the pop because I switched out head units 3 weeks ago and the pop turned to a tick. I also have 2 other friends running the 2180 who have the same pop noise on start up, one has changed his head unit and the pop went away.
but now that we are trying to figure out what causing all the speaker issues starting to think maybe it has to do with the pop noise..
and add this..
http://www.bestbuy.com/site/metra-gr...c&kpid=9855136
You don't want to use one of these. I'll send you one if you want to try it out, I have two here at the house. They act as filters and you will filter out lots of good sound trying to eliminate any ground loop buzz/hum.
Where is your remote connected to? If it's a the headlamp, try connecting to your radio. The delayed remote from your radio may turn things on in order and eliminate the "pop".
Do you also have a ground loop noise as well? If you have your volume at zero is there a hum/buzz? If so, take bare wire (speaker wire works fine) and wrap it in a figure 8 around your radio RCA's and then ground that wire to bolt on the radio.
Old Aug 30, 2015 | 11:29 AM
scumBAGGER's Avatar
scumBAGGER
no buzz or anything like that it just pops one time on start up.....if I have the ign on it does not pop till I hit the starter...the remote wire is hooked to the radio now.
Old Sep 6, 2015 | 07:31 AM
scumBAGGER's Avatar
scumBAGGER
I give.....need help....
I got the new 7.1p and I got it back in the bike now the "tick" is louder and it does it when I shut the bike off..
I really think its a ground issue now but have no idea just guessing.
the ground for amp is the way it should be (back to battery) but I wounder if its the ground for the radio? BT had me run a ground strap from back radio to neck but I thinking maybe the radio ground going to the Bt hand control might be wrong? so the radio ground wire is soldered to the Bt module is that correct?
I have issue sometimes when I go to turn radio down (mostly after longer stretches) when I look down at radio its flashing the the mode its in...so if I have it on usb it will be in the mode to switch to sirius,fm,bt audio,bt phone it does this alot I have dealt with it usually just by ejecting the face plate and then restart radio
Old Sep 6, 2015 | 09:18 AM
scumBAGGER's Avatar
scumBAGGER
when I turn the radio up and down when it goes from 1 to zero there is a slight tick\click
thinking this ground point is the issue. where does the ground in the bike harness go? battery or frame? if the frame then that make a "ground loop"?
Old Sep 6, 2015 | 09:20 AM
scumBAGGER's Avatar
scumBAGGER
I soldered everything so there should be no issue of loose connections
Old Sep 15, 2015 | 04:19 PM
HeHateMe's Avatar
HeHateMe
Default Blown biketronics
anyone else having issue with there 7.1p? I'v had 2 of them blow and now a 3rd has no volume? friends shop has had 2 go bad also!!!
I keep seeing good reviews and it sounds like most have good luck with them but I'm sure getting frustrated!!! cpl guys I ride with have the BT amp and Jl audio speakers and they have no issue at all, mile after mile...
thinking pulling trigger on set JL audio
I had two pair of blown biketronics speakers 7.1p. Both replaced under warranty.
I was done trying to trouble shoot. Replaced them with Focal KRC. Huge difference.
bigreds1963ss
Audio Systems
Oct 18, 2015 03:33 PM
Jason58104
Audio Systems
Aug 2, 2014 10:38 AM
ajohnston78
Audio Systems
14
Aug 6, 2013 11:35 PM
parkashard
Audio Systems
17
Jul 21, 2013 10:57 AM
Born2cure
Jun 14, 2010 11:06 AM
