After a couple of months reading as much audio information as I could take, I have finally decided on my set up to be. Install is for a 15 rgs. Going with cerwin Vega b2, arc moto 602, magic box from cycle sounds and their front speaker wiring harness. I am only doing the fairing speakers. I have a pbr 300x2, but I understand it's to weak to push the motos.
Question is.....what bracket options exist? Do I even need a bracket? Can it be installed using industrial velcro to something? Who sells said bracket if needed and how much are they? All feedback welcome. Thank you in advance
Come on fellas, there has to be more than 1 , 2015 roadglide owner that had installed am amp other than a biketronics or jm kit that comes with their amp.
Please share your roadglide mounting effort regardless of type of amp. Pics would be helpful
You can search post from dirtracin23. He post pic's of his install. I have bolted my PBR300 on a aluminum plate I cut the size I need and bolted it under the radio. Cost 5$ for 12x12 plate.
