CV B52 wiring help?
Old Nov 29, 2015 | 04:32 PM
ROCKOUT Rocker Products
Sponsor
Exclamation CV B52 wiring help?
Another thread got me thinking about my wiring on my B52 amp.... something sounds wrong.
I get that the striped wires are negative. I hooked the striped wires from the aftermarket harness I bought to the striped wires on the B52 provided connectors. But, the connectors/sockets on the amp don't seem to follow this theme?
Here's a pic of the input side, notice it says GROUND at the top..
Now here's a pic of the CV provided plug, notice the ground wires are at the bottom...
Now the output side, notice the L/R + and - are diagonal from each other on the socket....
And the plug, notice the negative wires are at the bottom, positive at the top...
It would seem that by following the striped to striped/solid to solid scheme I have it wired wrong? The plugs don't seem to match the sockets in polarity.
Help!
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Nov 29, 2015 | 04:42 PM
MichiganMikey's Avatar
MichiganMikey
Interesting. Will be following this for sure. I am having some issues with my B52 as well.
Old Nov 29, 2015 | 04:46 PM
Blowby's Avatar
Blowby
Should have my B52 tomorrow so I will follow this.
Old Nov 29, 2015 | 05:00 PM
Blowby's Avatar
Blowby
B2 wiring on current install. I was just going to plug the connectors in the new B52, that was my plan.
Old Nov 29, 2015 | 05:01 PM
Sponsor
Ok, um... never mind. It is wired wrong. I reused the plugs from my PBR300X2 on the B52 (they plugged in so they MUST be the same, RIGHT?), the +/- wires are in different places in the plugs DOH!
Move along. Nothing to see here...
Old Nov 29, 2015 | 07:11 PM
Sponsor
Soooo.... I posted in another thread that I found the BT 7.1s a bit lacking in bass & mid. DOH!
Because of the plug issue I had them wired the opposite of each other. Whereas I had the bass 2 bars from max before, I now have it 1 bar from centered, and it POUNDS lol.
Volume is quite a bit louder than before, I had to turn down the gain on the B52 a bit. Now I see what everyone was all excited about with the BT speakers.
On a side note, just to muddy the waters a bit...
Out of curiosity I checked the Polks I recently put in the rear pods. They do not follow the striped is negative theme, just the opposite. You can't put the wires on backwards 'cause the terminals are a different size. This is the factory harness...
Now to go track down that other post I made & fix it....
Old Nov 29, 2015 | 07:26 PM
Blowby's Avatar
Blowby
That sounds great that you can now hear the BT's do their magic! I can't wait to get my B52 tomorrow ....
Old Dec 3, 2015 | 06:25 PM
Gliden's Avatar
Gliden
What is a B52.....
I have a BT2180
What's the diff?
Old Dec 3, 2015 | 06:38 PM
Blowby's Avatar
Blowby
Cerwin Vega B52 amp.
Old Dec 3, 2015 | 06:40 PM
Gliden's Avatar
Gliden
Does that have more power than the BT2180?
