Biketronics install
Old Nov 30, 2015 | 07:04 AM
Tstreet15's Avatar
Tstreet15
Default Biketronics install
I am thinking about buying the biketronics amp and 7.1 speakers for 15 street glide. I have read that you have to put foam in between the speaker and fairing because there is a gap, and when removing speaker pods you take away the support for the fairing. Is this true.
Old Nov 30, 2015 | 08:41 AM
Gannicus's Avatar
Gannicus
Check out this thread and pay special attention to Bertk's post #5. Should be all the info you need.
https://www.hdforums.com/forum/audio...to-arrive.html
Old Nov 30, 2015 | 09:04 AM
NHBAGGER's Avatar
NHBAGGER
If you go with the brackets, there is also a good post by ROCKOUT about installing the brackets and firming up the inner fairing.
Old Nov 30, 2015 | 10:13 AM
barrygreen's Avatar
barrygreen
I originally posted the foam idea because I wanted to isolate the front of the speaker from the rear. I have the boom grills which are much thinner than stock. I felt like the speaker was getting to much air in the front coming from the rear. I used the foam to fill the gap and did notice a improvement in the sound. Do you have to do this...no.
Old Nov 30, 2015 | 10:46 AM
Tstreet15's Avatar
Tstreet15
I went ahead and purchase the biketronics kit. I hope I will be happy with it. With all the good reviews I should be.
Ultra2012
Audio Systems
Apr 6, 2019 06:12 AM
ALUCARD19
Audio Systems
Feb 10, 2015 12:34 PM
WildThang
Audio Systems
27
Dec 16, 2013 05:31 PM
Grunt66
Dec 9, 2009 03:06 PM
vertigo14
May 31, 2009 06:48 AM
