Competed New System Install - BT all the Way
I am about to do the exact install including using the Vtwin adapters to put Titians in the rear pods. Do you have a picture of the Titans in the rear pods that you could share with us. I'm wondering how the VTwin grills look with the Titans on the pods. Great write-up and thanks for sharing with us.
Jim
Jim
Another issue I ran up against was the length of the machine screws BT provides for mounting the speaker/ring combo to the BT speaker mount. They provide a 6 x 32 SS machine screw that's 1/2 in long if I recall correctly. After trying to make that work, it became clear that the screw was simply too short, so I went to my closest ACE Hardware store and purchased the next size/length up..3/4 inch I believe. You will use eight (8) of them....four for each speaker.
I will be interested in hearing where you end up mounting your line levelers. Using the BT wiring harness, the leads between it and the line leveler leads are not very long. So you will be somewhat limited where you can mount them.
The reason I ask is, I used the BT wiring harness and didn't account for the fact that the headlight sets deeply into the cavity and is right in front of the radio. And again, due to the length of the wire loom to the big connectors, you will be limited on where you can put the connector bundle once the wiring harness is installed. I would suggest you try to recess the big connector bundle deep into the cavity as far as possible below and to the brake side of the radio.
Removal of the two speaker pods also removed one or more locations used to secure the wiring to the bike with those push-in wire wraps. So be sure you have plenty of tie-wraps of different sizes/lengths. I would say I used more then 25 tie-wraps that weren't there before. I like my installations tidy though.
So let me/us know what your final install looks like. And good luck.
Jim
