resetting my amp gains after uping the BT355's, weird stuff...
Old Jan 23, 2016 | 03:47 PM
Bunker's Avatar
Bunker
Originally Posted by Bertk
There you go. Sounds dame good for a two speaker system.
What did you end up with gain setting on the LL's?
at maxxed volume it reads 2.0 volts out, I can got to 2.6 but backed it down a little. I had to go out in the parking lot across the way, was too loud in the garage
Old Jan 23, 2016 | 03:50 PM
Tailwind's Avatar
Tailwind
Originally Posted by Bunker
ummm so yeah, power hungry for sure!
here it is bridged:
That really sounds damn amazing!!! Very nice set up!!!!
T.
Old Jan 23, 2016 | 04:39 PM
wevsspot's Avatar
wevsspot
So you guys are able to run the Harley radio at max volume (17 clicks) or when you refer to max volume are you talking about the recommended radio volume at 13 clicks?
Old Jan 23, 2016 | 04:59 PM
Tailwind's Avatar
Tailwind
I could run max without distortion but the sweet spot is 13/14 clicks. Did the 80mph test today and that was a great spot to be on the volume.
T.
Old Jan 23, 2016 | 05:48 PM
Bunker's Avatar
Bunker
at stock settings (as shipped) the LL's would only allow me to get to 13/14 clicks before the clip light on my amp would come on. That was my 0.6 volt reading post.
I bumped the gains on the LL's up to max, 2.6 volts and I could max my volume all 17 clicks and never get the clip light to come on.
I've since dropped it to 2.0 volts and that's with the radio pegged at 17 clicks.
What you see in the above video is 17 clicks on the radio, output at the RCA jack reads 2.0 (with 1k test tone). Also I have bridged my amp so it's pushing 200 watts to each speaker
Old Jan 23, 2016 | 05:50 PM
Bunker's Avatar
Bunker
I tried to do a test video in the garage but it's seriously ear splitting loud, I had ot move the phone mic away as I was getting crackling because I was to close (that's why i move away quickly in the above video )
Old Jan 24, 2016 | 09:52 PM
Vision's Avatar
Vision
Pretty amazing. If I were only running two speaker in front on the 4180 I just ordered. I would have gone with the ARC Moto 602s for sure! I'm hoping the Titan 7.1s do me justice after hearing this. Damn.
Old Jan 24, 2016 | 10:22 PM
Bertk's Avatar
Bertk
The BT7.1's are very good speakers, you won't be disappointed. The main difference is the 602's have more bass.
Old Jan 26, 2016 | 01:01 PM
Babyboy's Avatar
Babyboy
Bunker
So with these settings you posted did you check the output voltage on the amp?
If you did what we're your readings.
BTW your system sounds good brother.
Old Jan 26, 2016 | 01:09 PM
Bunker's Avatar
Bunker
Originally Posted by Babyboy
Bunker
I posted my volts at the speaker ends in post #9.
Is that the output you're looking for?
