Help, please...
Old Feb 27, 2016 | 09:21 PM
nuttbaggerr's Avatar
nuttbaggerr
Default Help, please...
I'm about to install a biketronics 2180.14 amp and speaker kit in my '15 RGS. I'm looking at the backside of the amp and there's the connection ports for the speaker wires marked LF and RF and two marked L and F with the notation "Parallel connection 4OHM speakers only"
I'm only using two speakers in the fairings.
I have a white wire and a white wire with black line.
I have a gray wire and a gray wire with black line.
Which ports do I use?
I'm going to assume that I can use the whites on one speaker and the grays on the other speaker. They each have different size female spades and will connect accordingly to the speakers.
As you can tell, I'm a total noob with this.
Please help...THANKS!
Old Feb 27, 2016 | 09:54 PM
TomboAT65's Avatar
TomboAT65
You want the LF and RF, the other 2 are for another set of speakers. White should be for the left and gray for right if I remember right.
Old Feb 27, 2016 | 10:11 PM
nuttbaggerr
The large male/female spades are on the striped wires. Does this wire go to the POS or the NEG port on the amp?
Old Feb 27, 2016 | 11:34 PM
hbsoldier3's Avatar
hbsoldier3
Post this tread in the Audion section if you need answers you will find them a lot faster than in the Rushmore section.
Old Feb 28, 2016 | 07:58 AM
Roadie13's Avatar
Roadie13
Yes, you want the LF and the RF and definitely check the audio section for the polarity. The color on the amp labeling for LF and RF matches the color of the wire (white and gray). If I remember correctly the solid wire is positive and the one with the stripe is negative, but don't quote me on that, check the audio section.
Old Feb 28, 2016 | 11:11 AM
nuttbaggerr
sorry...duplicated thread after it was moved...I have another one here at audio...moderators please delete this thread or merge...thank you!
FLASH1970
Audio Systems
Sep 3, 2024 02:36 PM
Herbherb
Audio Systems
May 10, 2019 06:21 PM
macabra11
Audio Systems
Sep 11, 2017 10:12 AM
kyle31490
Audio Systems
Feb 9, 2015 11:35 AM
rapp76
Audio Systems
Mar 28, 2014 12:36 AM
