Stereo issues
Old Mar 11, 2016 | 04:21 PM
Thingamajig's Avatar
Thingamajig
5th Gear
Default Stereo issues
I have a 2007 ultra classic. Put the battery in it yesterday and went for a ride. All was good. About two hours in , sound would turn off for about five minutes then back on for a few etc, etc. Still doing today. Odd thing though, display still showing and in acc position works fine. HELP
Old Mar 11, 2016 | 04:27 PM
Babyboy's Avatar
Babyboy
What head unit is it?
Stock?
Aftermarket?
Old Mar 11, 2016 | 04:51 PM
sbeast's Avatar
sbeast
open up the fairings and double-check all your ground wires to be sure they're free of corrosion/tight. you could potentially have a voltage regulator issue as well (when my regulator went out, my stereo would cut in and out randomly)
Old Mar 11, 2016 | 06:54 PM
Thingamajig
5th Gear
That may explain the volt meter bounce I noticed bit then it seemed to even out
Old Mar 11, 2016 | 08:37 PM
sbeast's Avatar
sbeast
id double check the grounds first along with your negative battery terminal. i dont know how to troubleshoot the voltage regulator, but im sure theres a tutorial somewhere on here
Old Mar 11, 2016 | 09:35 PM
Babyboy's Avatar
Babyboy
You never said what head unit you have so everything is all guess work.
If you can tell the people in the forum what you have maybe someone has had the same problem and has found the cause of the problem to eliminate all of the guess work.
Old Mar 12, 2016 | 10:55 PM
Thingamajig
5th Gear
Head unit is stock . #76160-06
Old Mar 13, 2016 | 07:15 PM
Mirnldi@gmail.com's Avatar
Mirnldi@gmail.com
Probably has finally shaken it's self to death. If you want to stay stock look up iron cross audio. If you want to go aftermarket, your in the right place.
Old Mar 14, 2016 | 07:32 AM
paid4c4's Avatar
paid4c4
If it is a stock head unit your description is exactly what happened to my stock HU the past 3 times I had to it fixed under warranty. If you search the topic you will find a number of similar posts. On the good side I believe the HU I have now is going to be a keeper.
Bill
Old Mar 14, 2016 | 12:24 PM
Gannicus's Avatar
Gannicus
Yeah that! If your stock head unit has lasted this long on an 07 you've been a very lucky man! Time to fix or replace.
