Speaker question
Old Mar 21, 2016 | 12:42 PM
Roadking69's Avatar
Roadking69
Default Speaker question
I have fairing and saddle bag speakers and boom amps can i keep amps and just upgrade speakers?
Old Mar 21, 2016 | 01:04 PM
CallMeJus's Avatar
CallMeJus
As long as the impedance matches or is lower than the amps I believe.
Old Mar 21, 2016 | 04:45 PM
BlackPearl#1's Avatar
BlackPearl#1
Simple answer YES BUT....
RK69, please update your original post with everything you can think of that will help us answer your question. Year, model, stock audio, CVO?? Any info you can give us will help a lot. If FM reception is important, that will make a difference. Budget is another big question.
BE VERY CAREFUL with impedance. Impedance is measured in ohms and the lower the imp. the more audio you get, but also the harder on equipment it is. 0 is a dead short. Some of the Boom stuff is 1 Ohm. Reason I'd like ya to post up more info is so ya end up with the right stuff. Many of us here call the Boom stuff, KaBoom and if ya run much power to them, you'll know why they're called that. Be a little patient and don't run out and buy anything too quickly, many guys here that are very helpful and knowledgeable.
Kris
Old Mar 21, 2016 | 09:00 PM
Roadking69's Avatar
Roadking69
Bike is a 2015 RGS added hd speaker lids and speakers. Like I said I'm just looking at a better speaker wanting to leave my amps alone
Old Mar 21, 2016 | 09:15 PM
haze324's Avatar
haze324
Don't think you can with that amp set up. I believe the woofer and tweeter is powered separately from those amps; you're likely not going to find that in the audio market. Honestly even if you did I don't think those amps put out enough power to notice the upgrade in speakers. I would replace the amp/amps while your at it.
bignbald84
Audio Systems
Jun 29, 2017 07:52 AM
harley7316
Audio Systems
May 2, 2016 05:04 PM
08 geezer glide
Audio Systems
May 29, 2014 12:27 PM
2swild
Feb 27, 2012 12:30 PM
Mixter
Sep 14, 2011 08:48 AM
