RCA on the BT Line Levelers,,
Old Apr 11, 2016 | 10:19 AM
Tailwind's Avatar
Tailwind
The problem with the BT RCA is that unless u have 6 inches to make a course change, it will put stress on the connection. Think they are made with re-bar. So if u jam the outer fairing back on and it presses on those RCAs in any way, something is gonna have opposing pressure on it, namely the connections at the LL or AMP.
Go down and get some stingers at the local audio shop as those suckers are nice and soft and can turn on a dime.
Just my 02c.
T.
Old Apr 11, 2016 | 01:35 PM
Roadie13's Avatar
Roadie13
I spoke with Mike at BT a little while ago, this is the first he's heard of anyone having an issue. He recommended slightly bending the prongs like has already been discussed. He did grab a set of RCA plugs and a line leveler while we were on the phone and said the fit on the ones he grabbed was very snug and definitely didn't feel like it would work it's way loose and it took a fair amount of force to get it off. He also confirmed that the scalloped prongs around the male end of the plug do not go past the housing of the line leveler when fully seated. I mentioned to him that my plugs on the amp end were very tight, he said they should grab the line leveler every bit as solid as the amp.
Bottom line - they shouldn't be coming loose and if bending the scalloped prongs slightly doesn't take care of they are covered under warranty, just give them a call.
Old Apr 11, 2016 | 09:34 PM
JimTJr's Avatar
JimTJr
I had pictured something like you did Timbo, and was going to fabricate something out of small tie straps, the way you did it would be great. Also, Tailwind, I'll check into those maybe, Stingerz?
Sponger, those are the RCA cables that came with the BT system, look to be good ones, heavy gage and such.
Old Apr 11, 2016 | 09:36 PM
Bertk's Avatar
Bertk
Originally Posted by timbo141
Bert, that is how I explained to do so. I just used the ones I had laying around and the old converter. Didn't want to take bike apart to show what I did.
Yeah, I just had some laying around and thought I'd give it a try.
Old Apr 13, 2016 | 09:01 PM
JimTJr's Avatar
JimTJr
Stopped at a local audio shop today, they stocked Stingerz,, shortest set was 6 ft. Found these and bought them tonight, the part that hits the housing on my RCA cables is thinner and should go inside it I think. They will seat completely,, also only 18" long,, so no rolling up excess!
http://www.ebay.com/itm/361457542823
Old Apr 13, 2016 | 10:50 PM
Tailwind's Avatar
Tailwind
I think u are going to be very pleased with this purchase for a few different reasons. The main one being that there will be no side load pressure on the connections as u run these RCAs in a very tight space, unlike the BT RCAs that just have very limited flex.
I do think u will find the quality to be better as well but just my .02.
Good purchase Brotha!!!!
T.
Old Apr 14, 2016 | 09:04 AM
JimTJr's Avatar
JimTJr
Thank you Tailwind for the recommendation. I've never heard of them, but to be able to see them in person, and know what I was getting was nice. Glad my local dealer had them in stock. (Longer ones as I said) I hope 18" is plenty, should get rid of the loops required for the originals. Heck, maybe BT will start sending these with their systems,, that price is pretty good I think.
Old Apr 14, 2016 | 10:53 AM
JimTJr's Avatar
JimTJr
OOps,, in looking at my order, I realized that was only one pair! LOL,, Second ordered already, be in by the 19th.....
Old Apr 19, 2016 | 07:14 AM
JimTJr's Avatar
JimTJr
Changed post, see below, figured out how to do thumbnails, LOL
Old Apr 19, 2016 | 07:37 AM
HardRider1's Avatar
HardRider1
