FM ability is possible
Old Apr 22, 2016 | 07:53 AM
slyedog's Avatar
slyedog
Default FM ability is possible
Although I don't listen to FM much I found after doing my new install last night FM popped right on with many stations. Now prior I had 1 station. This is with the cheap Biketronics antenna that is just a piece of primary wire. So either my ZED amp emits no emi ( trucklite phase 7 still does), or which I think is the reason , is the 998 has HD radio. I have all stations my car gets and haven't got out of garage yet. So FM is possible with the phase 7 headlamp. Just not sure which is magic sauce. My money is on the HD radio tuner.
Old Apr 23, 2016 | 05:38 AM
restorick's Avatar
restorick
Perhaps. My setup has no problem with FM. I have Trucklites as well, including the driving lamps, along with an older Arc 125.2 amp under the fairing. I decided to modify the antenna brackets and go with a shorty external on my SG. Maybe I lucked out, but I can get any FM station my truck can.
Is there a way to measure EMI?
Rick
Old Apr 23, 2016 | 09:37 AM
haze324's Avatar
haze324
Rick
The Arc 125.2 is a class g/h amp and not class d that is normally the culprit of FM loss. Those Arc's retain FM reception.
Old Apr 23, 2016 | 06:03 PM
slyedog's Avatar
slyedog
Rick
I have no idea how you would. At work they have a bunch of shielding rooms to likely do something of the nature. Most all class D amps are known for this issue. I got lucky with my current amp.
Old Apr 23, 2016 | 07:30 PM
G E E's Avatar
G E E
Slyedog. Can you post link to your ZED amp? Thanks
Old Apr 23, 2016 | 07:41 PM
slyedog's Avatar
slyedog
Bought mine from this guy. Name is Andrew. I got last one but he may have more now. They are no longer being made from my understanding. Steve Mantz (ZED) Designs lots of amps for people. Was told he got tired of being a business man and went back to engineering amps for others. Andrew can direct you to one if he doesn't have it.
http://www.vertexaudio.com/Zed-Audio...d-mikro-iv.htm
Old Apr 23, 2016 | 08:10 PM
RatPwrd72's Avatar
RatPwrd72
After putting the B52 and Kenwwod HU in I lost all my FM signal and went the satellite radio route. It'll give me something to listen to after I get tired of 2,000 songs on the thumb drive, but the audio quality isn't quite as good.
Old Apr 23, 2016 | 11:23 PM
slyedog's Avatar
slyedog
I got xm added as well. $9 mount from moco and $30 for module. $60 for 6 months but the source level does suck. Had to change amp gains to that source and use volume offset on other sources to make it work. Nice to have though.
Porgey
Aug 18, 2019 10:56 PM
barrygreen
Audio Systems
17
May 29, 2015 06:27 PM
peramus
Audio Systems
Mar 18, 2014 06:20 AM
drrandall1
May 21, 2008 03:39 PM
dowork08
May 2, 2008 05:12 AM
