biketronics titan amp
Old Apr 30, 2008 | 04:14 PM
dowork08's Avatar
dowork08
Default biketronics titan amp
Is anyone using the titan amp, and if so they told me that if i run a underfairing antenna or listen to fm radio the amp may effect the reception. Has anyone ran into this problem, if so how bad is it. I dont really listen at all to my fm but would like it there for back up if satalite radio or ipod go out.
Old Apr 30, 2008 | 05:52 PM
dowork08's Avatar
dowork08
Default RE: biketronics titan amp
bump
Old May 1, 2008 | 07:35 AM
miacycles's Avatar
miacycles
We have had no problems with the Titan amp. Just make sure all your connections and grounds are tight and clean, dielectric grease.
Old May 1, 2008 | 08:52 AM
Sodiee's Avatar
Sodiee
Using a hidden antenna in your fairing will reduce the range it will pick up but I think it looks alot cleaner.I would guess that I lost about 30% range by using the Tune Trapper antenna.
Old May 1, 2008 | 03:52 PM
maxflhx's Avatar
maxflhx
The guy at Biketronics warrned me of FM static but I have no problems with mine.
Old May 1, 2008 | 05:12 PM
dowork08's Avatar
dowork08
hey max how do you like the amp. I have hogtunes speakers now, is it much better then that and what speakers are you running
Old May 1, 2008 | 05:33 PM
treeboy97Flht's Avatar
treeboy97Flht
I also interested in the post, I am looking to upgrade my audio
Old May 1, 2008 | 05:36 PM
dowork08's Avatar
dowork08
treeboy what are you lookign at getting maybe the biketronics retro radio kit with amp and speakers....bit of money but it would rock...and you would be able to upgrade fromthat 8track play i mean tape deck to a cd player.....
Old May 1, 2008 | 06:05 PM
e6fmf's Avatar
e6fmf
Recently installed the TITAN amp. Hardest part of the operation was removing and replacing the fairing on FLTR. Simple plug and play. Currently using J&M speakers, sound fine for my tastes.
Old May 1, 2008 | 06:42 PM
maxflhx's Avatar
maxflhx
Do Work,
I've got only good things to say about the amp, loud and clean power. I normally have it about 1/2 volume when it was cranked before. Easy to install. I'm using Polk/Momo MMC525 speakers. They push the grille out slightly but a little Gorilla glue fixed it. I can't compare them with Hogtunes but I'd run this setup again.
Hope this helps.
