Is the Harman Kardon Hi-level output voltage consistent
Old Aug 3, 2016 | 03:51 PM
CVOJOE's Avatar
CVOJOE
Default Is the Harman Kardon Hi-level output voltage consistent
Just curious if the Hi-Level output voltage on the Pre-2014 HD Harman Kardon radios was consistent or does it vary significantly radio to radio?
Old Aug 3, 2016 | 07:19 PM
jz78817's Avatar
jz78817
it shouldn't. pretty much all OE and aftermarket car/motorcycle radios pick from the same handful of 4-channel BTL amplifier ICs. they're pretty consistent.
Old Aug 4, 2016 | 11:59 AM
UltraNutZ's Avatar
UltraNutZ
Tony @ Iron Cross Audio can give you a definitive answer as he's tested this more than anyone I know but in my years, if it fluctuated there was an underlying factor such as corroded contacts on a circuit board, etc.
Old Aug 4, 2016 | 12:11 PM
CVOJOE's Avatar
CVOJOE
Thanks Guys,
I will check with Tony
DBLX
Feb 24, 2017 07:39 AM
Chicago Harley Boy
May 19, 2014 10:16 PM
racoonflhx1369
May 13, 2014 03:19 PM
PeteM
Jun 6, 2008 02:11 PM
Ultra Dickweed
Feb 17, 2005 02:35 AM
