New Bluetooth audio system
Old Sep 20, 2016 | 03:00 PM
rysonn's Avatar
rysonn
Default New Bluetooth audio system
I completed the install of my stereo system on my road king. Here is the system, then my question...
I went with the Soundstream st4 100db amp (I chose this amp because it is bluetooth.
I have a set of 6x9 infinity reference speakers in the lids. (yes I know at highway speeds I won't here much but I live near the daytona beach area and we don't do a lot of highway driving)
I have the whole system mounted up and all is working. The amp is bridged at 250W/channel.
The system is loud, there is no doubt about it. What I am finding, and where my question comes in is this.......As I said I am running the audio through bluetooth to the amp and I don't feel that the sounds is very full. I am not getting the lowes that the system is capable of putting out and it sounds a little tinny to me. I am using an iphone for the music.
Has anyone else experienced this with a bluetooth system? The amp has the capability of taking rca inputs but obviously then I would be using a "Y" cable plugged into the headphone jack of the phone which I was trying to avoid.
Thanks for your thoughts and comments...
Old Sep 20, 2016 | 06:41 PM
TwoBlue02's Avatar
TwoBlue02
I am not an iPhone user so I don't know if this exists......check for an EQ app to download. Your are hearing the flat sound direct from the phone
Old Sep 20, 2016 | 08:26 PM
Axle1980's Avatar
Axle1980
What do you have the crossovers on the amp set at? If you are high passed to high then that could be the problem. Check to see how low your speakers can play and set the crossovers to highpass there and adjust up to remove distortion. There is a equalizer setting on the iPhone however I recommend setting it to off as anything else will degrade the sound quality of the song being played. Ensure the sound check option is off as this affects the sound also. Lastly the file type you are streaming effects the sound quality overall.
Old Sep 21, 2016 | 05:15 PM
cbaker1@farmersagent.com's Avatar
confusing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!sameamp
trikky2
J&M Motorcycle Audio
Apr 21, 2016 01:30 AM
HeHateMe
Audio Systems
Aug 6, 2015 06:09 AM
Litewings
Audio Systems
Mar 12, 2015 04:11 PM
Nickblink
Audio Systems
Aug 6, 2014 09:27 AM
Ride4Him
May 27, 2010 10:17 PM
