Headroom?
Old Oct 1, 2016 | 10:21 AM
Cheesehead_13's Avatar
Cheesehead_13
Default Headroom?
OK, so I think I am starting to finally get some of these concepts. I have fairing only speaker set up (BT 7.1 non pro). I was wondering why my BT 7.1s don't sound like I expected them to. I think they may be underpowered. Could that be true?
Per the sticky, the PA bench tested at only 91w @ 4 ohms. I am guessing that I should have a true 120-180w @ 4 ohm amp. Does that sound correct? Previously I was thinking of bridging my PARZ4 2000D to those speakers to get more power but could be risky (possibly too much power).
Old Oct 1, 2016 | 10:38 AM
sponger's Avatar
sponger
Not to much power if you keep the gains down and dial it in with a dmm.
Old Oct 1, 2016 | 11:56 AM
Gannicus's Avatar
Gannicus
Sponger is correct. Turning the HU up to 75-80% capacity and then setting the gains by ear will get you where you want to be. Just listen for distortion and back the volume **** down a little when you hear it. You can then turn your stereo up to that set point and not worry about blowing your speakers. Your "Headroom" will be the 20-25% you left on the table. I don't use a DMM anymore. Some guys like it and I say to each his own. But I've found my ears to be more accurate.
Note* Make sure all your HU settings are FLAT when setting the gains.
KnarleyHarley
Audio Systems
25
Nov 12, 2017 07:12 AM
just plain john
Audio Systems
Jun 15, 2016 12:18 PM
HD REBEL
Audio Systems
Apr 15, 2015 12:10 PM
jamess71
Audio Systems
Sep 2, 2014 12:09 PM
just plain john
Audio Systems
Jul 8, 2013 05:22 AM
