Head unit help
The first one was great but I replaced it thinking I had a bad output. I troubleshot wrong and it was the soundstreem amp which was the cause.
The "new" Sony mex 70 Bt is a bit of a pain where by the demo mode keeps coming on by itself while riding regardless of shutting it off it still comes back on causing a lack of hand control while it's in this mode.
The first unit never did that.
It's got a few too many bells and whistles for me. If I had to buy another one I'd probably seek guidance from Mr. G and the boys and go a different direction.
Stay tuned. They will probably advise.
Nice name! Lol
Good luck.
Yeah that! If you are skeptical of the Sony. The Kenwood 998 is a great choice. Of course I love my Sony Mex M70BT. I have not experienced any of the issues as my friend Gliden. It's been a great HU for me!! But like anything else there's always a couple lemons in the bunch. I don't think you can go wrong with either. The Alpine CDE-HD149BT is also a very popular choice.
Each setup well vary and may need different EQ, Crossover, and speaker settings.
Here are some setting to get you started on the X998.
A lot of the options turned OFF in these settings are intended for car audio and would have no effect on a bike in the open air.
The following setting will have to be set for each source that you are going to use, ie USB, CD etc.
Maybe someone with the Pioneer Pros can chime in on X-over setting. I would be interested in what you end up with with these speakers.
It helps to keep notes by printing out page 18-23 from the manual
Note: Set or readjust the gains on the amp after making these settings. Aggressive EQ setting will have an impact on distortion.
(*) Can be set to your liking
Starting on Page 18
Set Drive Equalizer to OFF
Set Preset Equalizer to USER
* Manual Equalizer - Adjust GAINS to each Band:
Band1 = 3
Band2 = 2
Band3 = 2
Band4 = 1
Band5 = 0
Band6 = 0
Band7 = 0
Band8 = 0
Band9 = 0
Band10 = 1
Band11 = 2
Band12 = 3
Band13 = 3
* Q Factor: 1.50
Bass EXT: OFF
Pro Setup
DSP Set: Through
Car type: OFF
Speaker Settings
* Front speaker location: ON DASH
* Size: 6 1/2in
* TW: Medium
* Rear speaker location: Rear Deck
* Size: 6 x 9
* TW: Large
X/Overs Front (Using these setting set the amp x-over to All Pass, Flat, or Full)
* FC: 70 or 80
* Slope: -12 or -18
Gain: 0 (Or depends on the Amp)
* Tweeter FC: 4khz
* Tweeter Volume: 0
X/Overs Rear (Using these setting set the amp x-over to All Pass, Flat, or Full)
* FC: 70 or 80
* Slope: -12 or -18
Gain: 0 (Or depends on the amp)
* Tweeter FC: 4khz
Gain Left & Right: 0
DTA Settings
Preset Position: ALL
DTA: All of these should be set to 0
Channel Level: All of these should be set to 0
Sound Enhancements
* Supreme: ON or OFF
Space Enhancer: OFF
Sound Realizer: OFF
Sound Elevation: OFF
Volume Offset: 0
Bass Boost: OFF
Loudness: OFF
Balance: 0
* Fade:
EQ should look like this.
T.
