Speedy System
Old Oct 9, 2016 | 07:12 AM
tigerking's Avatar
tigerking
Default Speedy System
Hi all...newbie here...so far I have read a lot here but it seems that there was no specific mention of any system that sounds great at high speed; say above 100mph. Is there such a setup or it's just my wishful thinking?
Riding a 16 RGS now with Hogtunes Rev RG package which I am soon to ditch
Old Oct 9, 2016 | 08:02 AM
CVOJOE's Avatar
CVOJOE
Well Tiger,
A system can be done that can be heard pretty well @ 100 MPH. Most of what you're going to hear at that speed is going to come from your faring.
What kind of budget do you have to work with? That will really determine whether you're going to be able to put a system together as you're wanting.
There are some guys on here that have some systems I believe you could hear on the space shuttle, hopefully they will weigh in on this
Old Oct 9, 2016 | 08:27 AM
tigerking's Avatar
tigerking
Originally Posted by CVOJOE
Well Tiger,
Hi CVOJOE..I think 2000 is the max...wonder if this is sufficient
Old Oct 9, 2016 | 08:52 AM
Bunker's Avatar
Bunker
you want some kind of Pro Audio setup.
Here's my current setup and I can ASSURE you I can hear it at 100+. I could even tell when one of my rear speakers was out (bad amp, corrected now).
Fairing
DD VO 6.5's
DD B3 Horns
Powered by a Fosgate TM400x2
Lids
JL Audio M770 CCX
Powered by a bridged JL MX280/4
Old Oct 9, 2016 | 09:07 AM
tigerking's Avatar
tigerking
Fairing
DD VO 6.5's
DD B3 Horns
Lids
JL Audio M770 CCX
hi bunker ...but the dd is not weather proof right?
Old Oct 9, 2016 | 09:26 AM
Bunker's Avatar
Bunker
you can get all the DD products marine coated
Any DD Audio Product bearing the Marine Grade logo incorporates water resistant features enabling it to be used in applications where moderate exposure to moisture will not result in damage to the product.
Marine Grade products are not waterproof, and submersion or excessive moisture exposure may result in product failure. DD Audio Marine Grade products are not certified for saltwater environments.
Old Oct 10, 2016 | 07:33 AM
tigerking's Avatar
tigerking
is there any other recommendation for high speed clarity setup?
Old Oct 10, 2016 | 08:08 AM
haze324's Avatar
haze324
How many speakers? If more than two...what locations. Hertz SPL with Hertz horns is another very loud Pro Audio set up, and a bit louder than DD but not as punchy.
Old Oct 10, 2016 | 09:22 AM
tigerking's Avatar
tigerking
[/QUOTE]
Hi haze...just 2 speakers in the faring...ok will ck out hertz out...by the way do you have advice what 6.5 in the faring to pair with BT4180? I notice some of the speakers like 602 and kappa are not weather-proof but may ppl here recommend them..is it safe?
Old Oct 10, 2016 | 12:28 PM
haze324's Avatar
haze324
If you want the "loudest" at 100mph. The 4180 is the wrong amp.
I don't use anything marine or waterproof and live in Miami. My stuff gets wet all the time.
