CB part #76000486 versus #76000188
Old Jan 22, 2017 | 09:27 AM
wdeertz's Avatar
wdeertz
6th Gear
Default CB part #76000486 versus #76000188
I'm looking to add the CB/Bike-to-Bike module to my 2017 Ultra Ltd. The HD website fitment shows part #76000486 but the accompanying photo shows part #76000188. Is this just an outdated photo? Is there a difference between 486 and 188?
I've found a used 188 on eBay but before or Purchasing want to ensure proper fitment. Thanks
Old Jan 22, 2017 | 07:50 PM
Baeseman1's Avatar
Baeseman1
I'm not sure if anyone in here really knows how the new CB packages are put together. From the looks of it, the 188 is just the CB module itself. The 486 includes the 188 plus the mounting bracket.
Plugging in the unit and screwing in the antenna is probably the easy part. No idea how the PTT (Push To Talk) switch gets added on after the fact. Especially on a '17, you're probably better off talking to the dealer and asking what all is required.
Old Jan 23, 2017 | 03:49 PM
wdeertz's Avatar
wdeertz
6th Gear
Thanks, yes I confirmed with the dealer that part #486 is with the bracket while part #188 is the cb module only. The PTT switch is added by swapping out the right hand control with stock unlit switch or both sides with a lighted kit. Also need to add cb antenna and have headunit firmware updated.
Old Jan 27, 2017 | 02:00 PM
Dutch101st's Avatar
Dutch101st
Will any of the older models work? Like the 76236-06 (A, B, or C)?
Old Jan 27, 2017 | 02:29 PM
wdeertz's Avatar
wdeertz
6th Gear
No, the older models only work on 2013 and before (not sure how far back). The #76000188 cb module works on 2014 and newer.
Old Jan 27, 2017 | 02:50 PM
Dutch101st's Avatar
Dutch101st
Copy that...found a used -188 on ebay...thanks for the heads up!
triglide14
25
May 13, 2017 08:14 AM
Merri1
2014-2024 Touring Models
Aug 30, 2014 09:56 PM
MRKWMSN
Jul 16, 2014 11:13 PM
p51bombay
May 31, 2014 06:26 AM
Global Cooling
14
Apr 23, 2014 07:24 AM
