CD Stuck
Old Feb 7, 2017 | 09:11 AM
Drifter-10's Avatar
Drifter-10
Default CD Stuck
Ok so like the title says my CD is stuck in the radio. I have 2013 RGU and when I hit the eject button last night it went to just making noise and saying Disc Error 1. Hell I don't even have the option to choose CD right now. It goes from FM to WB.
And currently the money is not there to just swap out with a aftermarket. I actually had a Marine Kenwood deck in it and it stopped working cuz it got wet in the rain. I guess it liked a bath once in awhile but the rain Hell NO!!
Anyone got any ideas how to get it out?
Thanks
Drifter -10
Old Feb 7, 2017 | 10:02 AM
Bunker's Avatar
Bunker
there might be a little hole that you can insert a paperclip that will force an eject but tbo I don't know if that's an option on your head unit
Old Feb 7, 2017 | 11:17 AM
CVOJOE's Avatar
CVOJOE
I had a 13 RGC that that happened to. I lived with it for a little while and then the battery died and once I replaced the battery, it recognized the CD again and discharged my CD and started working again.
It might be worth the trouble to disconnect the battery and see if that works.
Old Feb 7, 2017 | 01:31 PM
Drifter-10's Avatar
Drifter-10
Thanks guys.
I have some ideas on how to deal with it when I get home this evening.
I think work would frown on me working on the bike now.
Thanks
Old Feb 7, 2017 | 01:38 PM
TriGeezer's Avatar
TriGeezer
Iron Cross Radio has been a great company to deal with, and they're a sponsor. Maybe a nice call to them, and they can offer free advice. Tell them based upon recommendations on this forum you are thinking by of sending it to them but hrs such a PITA to remove, maybe they can make a suggestion.
Edit: I just did some Googling, so try:
- don't disconnect at the battery, turn the radio on, then pull and replace the maxi fuse a couple times.
- open the door and go for a ride on a bumpy road
- open the door and smack the radio a few times.
- try to pull it out with long nose thin needle nose pliers...this will likely ruin the CD though
- listen to your smart phone or iPod through the audio plug
- send it to Iron Cross, and for $250 they fix it with a full 1 year warranty. While it's there, consider some of the upgrades they do.
Old Feb 7, 2017 | 02:48 PM
470004's Avatar
470004
I agree with TriGeezer and give Iron Cross Audio a call.
Old Feb 8, 2017 | 05:12 AM
Gannicus's Avatar
Gannicus
Thanks
Drifter -10
If you've already had a Kenwood in there once. I assume you already have your hand controls covered with an install kit. If that's the case here is your best and cheapest option:
https://jet.com/product/detail/bde34...6iIhoCqzvw_wcB
TriGeezer is spot on with the Iron cross recommendation. But it's gonna cost you at least $250 and IMO another $250 bucks in that radio is not worth it.
Old Feb 8, 2017 | 09:35 AM
Drifter-10's Avatar
Drifter-10
Thanks
Drifter -10
Just to update this for those that may run across this problem.
I was able to get the CD out of the radio. After all the suggestions I was able to take a second disc and try to put into the player and after several attempts it spit it out like it should. This was CD-R disc that had been in for a long time. So I got brave and found a bought disc and tried it real quick and it went in and out no problem. Maybe it doesn't like the CD-R disc but not sure why.
I did pull the main fuse and it did not work.
I also rode about 20 miles with the CD door open and nothing.
I had read that these two ideas had worked but not for me.
Anyway its out and the radio is back working.
Thanks for the ideas and yall be safe
Old Feb 8, 2017 | 10:39 AM
470004's Avatar
470004
Glad it worked out for you without any damage and/or cost.
scoobydiver
2014-2024 Touring Models
Mar 6, 2018 08:01 AM
harleyd1500
Jan 25, 2018 02:56 PM
Black_Gold
21
Jul 21, 2017 08:19 AM
vtwinhd59
Mar 4, 2012 11:41 PM
dfmoberg
Jul 21, 2011 06:42 PM
