Amp porn
Old Feb 13, 2017 | 09:53 PM
slyedog's Avatar
slyedog
Originally Posted by pdevore
I think your D2 gave birth
To date, that is the most powerful /smallest amp on the market that I know of. 200rms bridged from that little bastard
Old Feb 13, 2017 | 10:04 PM
matt76cmich's Avatar
matt76cmich
Originally Posted by slyedog
Got any extra JM stickers to spare?
You know i can't give up my stickers, each one adds 5 db! Lol
For real though, looking forward to how everything turns out.
Old Feb 13, 2017 | 10:05 PM
matt76cmich
Originally Posted by Fatherwayne
It'll probably power the regular Rockers but you know as well as I do it can't handle the Rocker Extremes. JM John truly believes they are the finest motorcycle audio components on earth and the 3 next closest planets. Nothing in the universe can power them properly but only the Rocker amps can even attempt to "rock them all night long" . It's the re-branding sticker over the top and the extra few hundred you pay for it that makes it able to even attempt to power the mighty 7.25 behemoths.
That's just funny, lol.
Old Feb 13, 2017 | 11:08 PM
pdevore's Avatar
pdevore
I am planning on seeing how much it will push, and because I can't leave well enough alone I ordered a second one too.
We need to get this thing tested.
Old Feb 14, 2017 | 08:30 AM
cpbedor's Avatar
cpbedor
.....I ordered a second one too.
Pete will be the first guy on the planet to be running 8 in-fairing amps and still have room for a DSP and a ham sandwich
Old Feb 14, 2017 | 10:43 AM
Makdaddy's Avatar
Makdaddy
Guys that little Pico is only bridged to 1 channel @ 200 watts for a Sub
Its a 2 channel that will get 100watts @2 ohm
2 channel amps bridge to single output
4 channel amps bridge to 2 channel stereo
Old Feb 14, 2017 | 11:27 AM
Tailwind's Avatar
Tailwind
No worky for my setup.
T
Old Feb 14, 2017 | 11:52 AM
pdevore's Avatar
pdevore
When bridged it is 200watts to 1 channel at 4ohm. If running a DSP theoretically you could run one to each woofer and one to a set of tweets.
Old Feb 14, 2017 | 12:21 PM
Makdaddy's Avatar
Makdaddy
Pete
Could work that way
Not sure how much left to right channel separation you may loose
Typically 2 channel amps bridged create one mono output
But I would, be curious to hear. need to find a song that has distinct music on one channel like a guitar rip.
See if it follow when the amp is set to bridged
Old Feb 14, 2017 | 12:38 PM
pdevore's Avatar
pdevore
Pete
Could work that way
I agree,
I think the best use of it may just be for horns and tweeters. Mosconi is known for having some of the cleanest output and running only to highs should sound great. I am not sure what I would gain in using one bridged to each woofer, not many of these woofers will handle a true 200w all the time unless you are talking pro audio. There are cheaper options to get the 150-200w a channel than using these guys. But, I think these guys are a really cool idea and because I like to try different things I may try it to see how it works and sounds.
