System problem since upgrade
Old Mar 1, 2017 | 07:55 AM
Tailwind's Avatar
Tailwind
I'm thinking that this is one option.
T
Old Mar 1, 2017 | 10:38 AM
dgoode01's Avatar
dgoode01
This is my current setup. Sorry, for the horrible drawing
Old Mar 1, 2017 | 10:44 AM
09baggerdude's Avatar
09baggerdude
T
A picture says 1000 words...lol
Old Mar 1, 2017 | 10:45 AM
09baggerdude
Originally Posted by dgoode01
Attachment 501091
Having a tough time with the pic. It's just not focused, but make it look like Ts pic and you're good to go!
Old Mar 1, 2017 | 10:46 AM
SBates08's Avatar
SBates08
Attachment 501091
If you've got it hooked up exactly like your drawing then no wonder your having issues.
When you attach a set of Y's to your cables you now have 2 reds and 2 whites. The front channel of the amp MUST HAVE 1 red and 1 white. Same goes for the rear
Old Mar 1, 2017 | 10:50 AM
dgoode01's Avatar
dgoode01
Let me go back and verify, I'm going off memory.
Old Mar 1, 2017 | 10:55 AM
SBates08's Avatar
SBates08
Most people can relate RCA colors to red and white. When you introduce a set of Y splitters, now you have 2 reds and 2 whites at the end of the RCA. You take one red and one white for each channel. Your drawing suggests that you have 2 reds on one channel and 2 whites on one channel on both amps. That won't fly and stands to reason why your setup sounds like crap.
Old Mar 1, 2017 | 11:40 AM
Bertk's Avatar
Bertk
Using colors only, this is how the front should be connected.
Red is red and black is white in the diagram.
Edit: The front outputs will include the faring and tourpak speakers.
The rear outputs are reserved for the JL amp/Pioneer Pro's.
Use T's diagram to wire the JL amp.
Old Mar 1, 2017 | 11:54 AM
slyedog's Avatar
slyedog
I would not split about a way that allows you to keep front and rear in this setup. You need the 998 xovers for the 4180. So if you keep the front inputs to the 4180 you will have the tour pack and fairing, which can use the same xover frequency and then the rear output to the JL to have a lower freq for the Pioneer Pro.
Old Mar 1, 2017 | 12:24 PM
Bertk's Avatar
Bertk
You are correct. I should have been more clear on that.
