Install for d
Old Mar 31, 2017 | 07:30 PM
Bertk's Avatar
Bertk
Originally Posted by bobbyjoes
that black plate that sits on those little dowels was loose ,I glued it back down,there was glue on it but came loose I guess,the other one was good
That should take care of it.
Old Apr 1, 2017 | 07:38 PM
bobbyjoes's Avatar
bobbyjoes
Originally Posted by BaggerAudioLab
Run the amp in two channel input and use right and left RCA's into those inputs on the amp. For your right speaker use the connect the positive to positive on channel 1 and the negative to negative on channel 2. For the left speaker do the same with the positive of channel 3 and neg of channel 4. Then tune each side independently.
when talking right side speaker we are talking brake side right,thanks
Old Apr 1, 2017 | 08:30 PM
bobbyjoes's Avatar
bobbyjoes
Little update,now how to hook up LL and the rem?thanks for the help
Attached Thumbnails Install for d-20170401_201733.jpg   Install for d-20170401_201643.jpg   Install for d-20170401_201612.jpg   Install for d-20170401_201540.jpg
Old Apr 2, 2017 | 09:05 AM
bobbyjoes's Avatar
bobbyjoes
could someone tell me in simple terms how to hook up LL to d4,tailwind is helping me but he is out on a ride ,so he wanted to hook up in mono using rca`s and y adapter, i took couple pictures ,thanks to all who helped so far,Bob
Old Apr 2, 2017 | 01:23 PM
Tailwind's Avatar
Tailwind
Check ur texts. Pics sent.
U gonna use the JL280/4 for the Pioneer Pros in the lids?
T
Old Apr 2, 2017 | 02:08 PM
bobbyjoes's Avatar
bobbyjoes
T
Well this is what I did before pictures,I used the y adapters coming out LL then hooked male rca and put first to input 1 and 2,then put other y and male rca to input 3 and 4
Attached Thumbnails Install for d-20170402_135459.jpg   Install for d-20170402_135602.jpg   Install for d-20170402_135636.jpg
Old Apr 2, 2017 | 02:25 PM
bobbyjoes's Avatar
bobbyjoes
otherwise i dont know what the y`s are for,anyone ,
Old Apr 2, 2017 | 04:12 PM
bobbyjoes's Avatar
bobbyjoes
T
yes JL for rear pioneer
Old Apr 2, 2017 | 08:02 PM
bobbyjoes's Avatar
bobbyjoes
Thanks Haze and Tailwind ,we got it,will tune tomm hopefully
Chucks1911
Audio Systems
May 4, 2018 07:20 AM
KSGLIDEGUY
Audio Systems
36
Mar 1, 2018 12:52 PM
big- mike
Audio Systems
Jan 17, 2018 11:29 AM
JoshuaCannon
Audio Systems
18
Apr 28, 2014 02:16 PM
Strait
Audio Systems
Apr 5, 2013 04:27 PM
