Install for d
Old Mar 29, 2017 | 05:57 PM
bobbyjoes's Avatar
bobbyjoes
Default Install for d4 help
Ok,finally got all my stuff to in install digital design d4 amp,i have the aw 6.5 and tweeter installed ,not wired,I have no idea how to wire and bridge for mono,is there a step by step install thread for this,thanks
Old Mar 29, 2017 | 06:02 PM
BaggerAudioLab's Avatar
BaggerAudioLab
Run the amp in two channel input and use right and left RCA's into those inputs on the amp. For your right speaker use the connect the positive to positive on channel 1 and the negative to negative on channel 2. For the left speaker do the same with the positive of channel 3 and neg of channel 4. Then tune each side independently.
Old Mar 29, 2017 | 06:59 PM
bobbyjoes's Avatar
bobbyjoes
Sorry I'm so simple but,let's start with tweeters speaker,crossovers,taking pictures too get it right,so how you wire this first,thanks
Attached Thumbnails Install for d-1490831694429739848266.jpg   Install for d-1490831729847-1196257084.jpg
Old Mar 29, 2017 | 10:49 PM
cpbedor's Avatar
cpbedor
Follow your crossover wire and see that the positive wire is covered in --- dashes which in my brain meant "negative" Obviously not the case. Start with making sure the crossover wires are going to the proper leads on the tweeter! I had mine backwards to start with
Old Mar 30, 2017 | 04:49 AM
bobbyjoes's Avatar
bobbyjoes
Ok,I will try to do it this weekend ,work is getting busy,thanks so far for the help,going to take it slow,ha
Old Mar 30, 2017 | 03:21 PM
bobbyjoes's Avatar
bobbyjoes
Can you take covers off crossover digital design,one has a rattle in it ,just wondering
Old Mar 30, 2017 | 03:55 PM
cpbedor's Avatar
cpbedor
Easily. Just like opening up a can of snuff. They pop open and close back shut without issue.
Old Mar 30, 2017 | 04:31 PM
bobbyjoes's Avatar
bobbyjoes
Thanks bud,didn't want to break it,thanks alot
Old Mar 30, 2017 | 10:18 PM
Bertk's Avatar
Bertk
There shouldn't be anything rattling within the crossover!
Old Mar 31, 2017 | 05:09 AM
bobbyjoes's Avatar
bobbyjoes
that black plate that sits on those little dowels was loose ,I glued it back down,there was glue on it but came loose I guess,the other one was good
