Starting from Scratch
Old Apr 17, 2017 | 02:29 PM
swmpman's Avatar
swmpman
6th Gear
Default Starting from Scratch
Let me start off by saying I am an amateur when it comes to stereo equipment. I can install about anything but when it comes to knowing what to get I am lost. I was debating between the J&M and the Hogtunes but after reading several threads on here I am realizing that I can do better with some different manufacturers.
The reason I was looking at those two was because it seems like they offered kits that had everything I needed. I am not against piecing together parts but my problem is that I don't know what parts to get. I have searched all over and can't seem to find a "shopping list" of parts if you will. Several different speakers and amps are mentioned but not the other things that I will need to do the install.
I have a 2013 Ultra Classic and I am wanting to get an amp and change out the speakers in my fairing and install some speakers in the lowers. I could change out the speakers in the rear pods too but it's not as important since my wife says most of what she hears comes from the front anyway.
I know this is kind of a broad question but could someone point me in the right direction to start piecing together a new set?
Old Apr 17, 2017 | 02:37 PM
BaggerAudioLab's Avatar
BaggerAudioLab
If you are looking for easy install and that sounds good off the bat I'd check out Biketronics.
Old Apr 17, 2017 | 02:53 PM
swmpman's Avatar
swmpman
6th Gear
Is the BT4180 worth the price difference over the BT2180. If it matters I may be connecting the back speakers at a later date.
Old Apr 17, 2017 | 03:27 PM
cpbedor's Avatar
cpbedor
the 2180 (2 channel amp) will run your fairing and your lowers and that's where it ends.
the 4180 (4 channel amp) will run your fairing and lowers on the front channel and the pods on the rear channel.
You're buying two 2180s when you buy a 4180.
Old Apr 17, 2017 | 03:49 PM
bob 103's Avatar
bob 103
Default new
i just bought a pair of 6.5 speakers with a marine amp all from Hertz just done 120 miles on the A1 in uk and sounds great even at 90mph
very happy with all my bits only cost £390 sterling
Old Apr 17, 2017 | 04:17 PM
Tailwind's Avatar
Tailwind
What's ur budget?
U staying with the stock HU?
If u can crimp a few wires and work a screwdriver and a wrench I personally don't see a need for a "plug and play" setup. Bang for the buck goes up tremendously if u put the kit together yourself.
T
Old Apr 17, 2017 | 04:26 PM
yooperhog's Avatar
yooperhog
Originally Posted by Tailwind
What's ur budget?
T
hey T
dont most of the "plug n play" set ups require dang near as much work as the customs? still takin fairing apart, pulling gas tank to power amp?
Old Apr 17, 2017 | 04:44 PM
Tailwind's Avatar
Tailwind
Originally Posted by yooperhog
hey T
Absolutely!!! The only real difference is that everything comes in one package imho.
T.
Old Apr 17, 2017 | 04:46 PM
yooperhog's Avatar
yooperhog
T.
im sure haze would put everything in one box if a guy asked nicely
Old Apr 17, 2017 | 05:22 PM
cpbedor's Avatar
cpbedor
I'm sure any number of qualified people would put together a list of everything he needs down to the wire connectors. Just need to know if he's willing to put it together and what he wants to spend!
