Flash radio before or after amp install?
Old May 28, 2017 | 05:41 PM
kabory's Avatar
kabory
2nd Gear
The only thing the 0 amp 4 speaker flash does is enable the rear fader controls. 99.9% of users that I have seen, do not use the fader. You dont need a flash unless you are going to use Harley amps or you want the use of the rear
fader. All you need is line levelers or resistors/signal harness (which are better IMO) check out americanhardbag.com they have alot of info and products there.
Correction, the flash will enable rear fader and activate the rear speaker wire plug inside of the fairing. You dont need to flash if you are just using 2 speakers or your amp has 1 input and 2 outputs. You do want to flash if you are sending the front and rear outputs of the stock HD radio to your amp front and rear inputs. either way, you will need line levelers or resistors to get rid of the harsh Harley eq.
Hope this helps.
Old Feb 10, 2018 | 09:06 PM
actfitwil's Avatar
actfitwil
Finally Got my Flash done today after being refused two previous times due to Harley BS. Had to remove aftermarket lids and put stock back on . stupidity. I hope they got the Ultra flash correct. I did 0 Amp and 4 speaker to avoid my " HU from explosion". As I was told by the tech. what a joke. and Hopefully the next time I do the usb update I hope they don't inadvertedly remove my flash.. I did notice the volume was reduced after flash. I will post an update after I finish the install.
Plan- 2, MX 6.5 Mille pro Hertz in front fairing and 2 st25 hertz tweeter, pushed by Diamond Micro 4v2 Amp. and 4, 6x9 pioneers in rear pushed by Alpine 4 channel. all this will be flatten by DSR1 rockford DSP. I know i didn't need flash with the DSR1 but I just prefer a flash. I want all my functions out the bike I own. RGs 2017. stay tuned..
Old Feb 11, 2018 | 01:11 PM
mikes300's Avatar
mikes300
Hope this helps.
I like having the fader option, I’ll generall turn the rears up whil on the freeway then back to normal for everywhere else. And yes you need the flash to activate the rear channel output
Old Feb 12, 2018 | 11:46 AM
Choppie's Avatar
Choppie
Hope this helps.
New to the audio section and went through a few threads about flashing but my head is spinning now.
I have a standard audio setup on 2014 Ultra Limited with normal four speaker setup. If you just want to add an amp and 4 new speakers I understand you don’t have to flash unless you want the fader. Right now I don’t care about the fader as I never used it before.
So there is no need for flashing? Just line levelers or resistors as stated here?
Old Feb 12, 2018 | 11:54 AM
SBates08's Avatar
SBates08
Your bike already has the correct flash. All you need is the BT355 Line Levelers.
Old Feb 12, 2018 | 12:11 PM
Dsm Limited's Avatar
Dsm Limited
To expand on SBates reply, if you want fade control you'll use 2 BT 355's. If you truly don't care about fade, you can get away with 1 line leveler
Old Feb 12, 2018 | 12:20 PM
Choppie's Avatar
Choppie
Thanks guys. Much appreciated.
Old Jun 26, 2021 | 01:16 AM
dirtyktm's Avatar
dirtyktm
Stage II
Hope this helps.
Sorry this info is incorrect. -- Your flashing to get rid of the Harley installed EQ so you dont blow up your speakers. Harley installs a preloaded EQ for some reason and this will cause distortion and rattle the expensive speakers if you installed a new amp also. - The flash gives you a Flat EQ to match your more powerful amp. If your not installing an amp you can probably leave the stock stereo as is
I guess a Line Leveler would be doing the same thing, flattening out the stock Harley EQ
Old Jun 29, 2021 | 09:36 AM
mikes300's Avatar
mikes300
this, now that all the new flashes are available, i went with a flatter flash removed the line levelers and have a much better sounding system. I feel the LL were needed when no one knew how to get rid of the stock curve, now that they can its no longer needed, assuming you try a different flash.
Old Jul 23, 2021 | 08:29 PM
Chunky Monkey's Avatar
Chunky Monkey
what flash do you ask for besides the 0Amp 4Speaker ultra flash. I put in a arc audio 600.4 with the bt-355 fr and rr and need to do the flash. I go in tomorrow.
