Alright guys, with tuning the amps freq using the CC-1 which crossover format do you set the amp at?!
The amp is a Diamond HXM 800.4 and it's pushing a 6.5/horn on ch 1&2 and 6x9 on 3&4.
Front two channels at 100hz and rear at 80hz.
The amp doesn't have a full pass through like the manual says to use, so do I set it on low pass, flat, or high pass to adjust to the appropriate freq?
