bluetooth wiring question
Old May 20, 2017 | 05:14 PM
murph's Avatar
murph
Default bluetooth wiring question
I'm not sure if what I'm trying to do is going to work, but I'm going to try.
I have purchased a packtalk communications set to use on my up and coming sturgis trip. Everyone else in the group already have them.
I want to listen to my radio from the bike to my packtalk. I know i can connect to the packtalk using a bluetooth transmitter. I already have one in mind. (TAOtronics tt-ba09) I've talked to their tech department, and they told me it will work for my application.
I presently have an amp wired to the two speakers in my fairing speakers. The amp uses a remote wire to turn on. I had purchased the panel switches to wire up my garage door opening, and have an unused switch. I was going to wire the remote wire for the amp through that switch. This way I can deactivate my amp when I'm using my Cardo Packtalk. (There is a delay in bluetooth).
Here is my problem. How do I wire my output of my radio to the 3.5mm input on the bluetooth. the output of my radio is + - for left and + - for right which is four wires total. The wiring for a 3.5mm plug is three wire. (left, right and ground). The question is.. can I wire the two negatives from the left and right outputs together.
Should I wire the 3.5mm plug before the amp or after the amp. Will this cause a ground loop problem when I'm not using the Packtalk and using my amp?
Thanks for any help.
Murph
Old May 20, 2017 | 05:27 PM
sr230mike's Avatar
sr230mike
Bluetooth wiring hmm anyone else see the humor in this"? sorry Murph
Old May 20, 2017 | 07:37 PM
murph's Avatar
murph
Well they don't make a plug and play bluetooth transmitter for HD...lol
robert.schoelkopf@gmail.com
Audio Systems
Oct 30, 2015 10:21 AM
toddrick
Audio Systems
Apr 29, 2015 08:42 AM
Bertk
Audio Systems
Feb 5, 2015 06:49 PM
D RENEGADES
Audio Systems
Feb 28, 2014 12:27 PM
Bo Joe
Mar 30, 2013 10:35 PM
