Setting gains without a load is fine BUT all amps when spec for rated output are ran off a load and at typically a 1k wave. Now sub amps are a while different animal nit worth discussing. Unless you have a resistor bank the load setting is not possible. I have done both ways, especially initially checking clipping point with scope. But none the less gains are so sensitive I find making a mark trivial as even the slightest increment more or less can be as big as 50+ watts depending on amp and source voltage. YMMV. Practice the kiss method people.
I would also like to add
that $10 harbor freight DMM may look cool
But you really need whats called a true RMS meter
Spend the extra coin , its the only way to go
LOL. I hear you bro. I'm OCD and tend to overthink everything.
Just jacking w ya brotha in good fun. OCD kicks the shix out of me even when I sleep man!!! It can be a good thing though. We like shix done right!!!
On point, I have not used any of my tuning equip in at least a year so my ears are getting wiser. Just never had any luck setting a number and getting quality or effective sound.
It has been like that too since I was a kid, asnd it has rained a lot since then.
T.
You are a young fella. At 55 my ears might be wiser, but I'm deaf.
What is an aceptable volume level for must people around me, it is extremelly low for me, and viceversa.
