thanks T, I appreciate the feedback. You mentioned there being good shops in NC. Any you would recommend or at least city location so I can track them down :-)
Lots of options. As Bagger mentioned u have Backyard Baggers up in Winston-Salem but you also have Chris Lowe / Garage Bagger Stereo about 2 hrs SW of u in Taylors. Chris and his team has tons of options and could throw together a complete plug and play system for u. Think they are also ramping up their internet sales division so give them a shout to check on potential package deals.
I can tell you first hand that those components are spot on. I put those very items on my ride and it ROCKS!. Alex took care of me and was very helpful when I had a few crazy questions. It was a bit intimidating at first but it turned out to be an easy install and the results are amazing! I'm on to stage two for me. Lids and DD VO 6x9s.
Thank you for all of your responses. The setup that you suggested, is this a diy or someone install this? Is this plug & play? Getting the bike on Thursday.
The Biketronics Line Levelers (BT355) are the key to "plug and play" thus u will not have to cut into any HD wires. Coming out of the amp u will more than likely just run new speaker wire.
T.
for this set up and others that are similar, how weather proof is the system, i.e. Speakers and tweets
When you do the AT28 tweeters, do you have to drill holes in the fairing?
Mount them in the smack dab middle of the speaker grilles. Most of us have bought the hogtunes grilles and used those instead of the stock grilles to mount the AT28s.
