JL Amp
Old Aug 7, 2017 | 10:07 PM
dfin's Avatar
dfin
5th Gear
Default JL Amp
i have a JL500 watt 4 Chanel amp. After it plays for a while it cuts off. Any suggestions?
It turns off when its real hot out side
Old Aug 7, 2017 | 10:10 PM
Mchad's Avatar
Mchad
A small 12v pancake fan running off the 12v trigger power?
Old Aug 7, 2017 | 10:15 PM
dfin's Avatar
dfin
5th Gear
will that pancake fit inside a 17 road glide fairing if so where can i purchase one?
Old Aug 8, 2017 | 05:53 AM
BaggerAudioLab's Avatar
BaggerAudioLab
What are you running off that amp? That amp doesn't get too hot. What size power and ground, where are you grounded too and how did you set your gains?
Old Aug 8, 2017 | 06:19 AM
Mchad's Avatar
Mchad
An Amazon search for "small 12v fan" returns many. For example:
Amazon Amazon
40mm is probably shorter then the amp height. There's a 60mm also on the first few results.
Old Aug 8, 2017 | 06:49 AM
BlackPearl#1's Avatar
BlackPearl#1
Please please listen to this man. No question, he will lead you in the correct direction and knows what is going on and has been there and done that.
Kris
Old Aug 8, 2017 | 07:01 AM
Gannicus's Avatar
Gannicus
Yeah - I gotta agree with Haze. Those JL amps don't get hot. Something is causing it to get hot in your set up. If it's cutting off there's a reason. Gain settings? Juice from the battery? Ground? Connections? RCA's? How do you have it mounted to the radio? What size wire are you using? See where I'm going with this? Check all the above and get back to us.
Old Aug 8, 2017 | 07:40 AM
yooperhog's Avatar
yooperhog
dont put a band-aid on a broken leg. figure out why it is overheating
Old Aug 8, 2017 | 09:05 AM
dfin's Avatar
dfin
5th Gear
8 gauge, for both, ground to battery first the added ground to the bike frame to try and remedy the issue.
DoubleD8
Audio Systems
Apr 14, 2019 04:32 PM
Baggergee
Audio Systems
11
Mar 18, 2019 08:32 AM
BaggerAudioLab
Jun 6, 2018 03:33 PM
wiguy
Audio Systems
Mar 15, 2016 09:39 AM
haze324
Audio Systems
Mar 9, 2016 05:26 PM
