BT 4180 System Low End Question
Old Aug 25, 2017 | 10:38 PM
Mach1FB's Avatar
Mach1FB
Default BT 4180 System Low End Question
Hey all, I think I know my limitation is the 4180 from research, but wanted to see if there was a way to get more bass out of my system?
14 Street Glide
Aftermarket head unit
BT 4180
7.1s in fairing
Hogtune lids with 6x9s that come with them
Are the pre set levels of the 4180 my limitation as I suspect? I went with the BT set up for plug and play simplicity. It rocks and is great, just lacks the low end like I've heard people say.
Thanks!
Old Aug 26, 2017 | 06:40 AM
Tailwind's Avatar
Tailwind
Those 7.1s are inherently fairly bright speakers so that's probably the closest alligator to the boat. The default settings on the BT355 crossed in the 80s would the a baby alligator.
T.
Old Aug 26, 2017 | 07:55 AM
UltraNutZ's Avatar
UltraNutZ
when you call to order your 4180, ask them for the 10hz roll off version which will provide more low end.
the normal version I do believe has a 45hz roll off for bass response.
Old Aug 31, 2017 | 09:47 PM
Mach1FB's Avatar
Mach1FB
Thanks for the replies. I have had everything in the bike for the past year or more so I can't switch to the other roll off 4180. Is that something that can be done myself or from biketronics only?
What would you recommend to swap out my 7.1s for a less bright speaker?
Thanks in advance!!!
Old Sep 1, 2017 | 02:29 PM
UltraNutZ's Avatar
UltraNutZ
Mach1FB. their products have lifetime warranties so I'd pull it and send to them if you want it done. Aside from that, maybe another choice of amp that doesn't restrict the low-end response. if you want less-bright, stay away from Focal speakers..
Old Sep 2, 2017 | 10:32 PM
Mach1FB's Avatar
Mach1FB
Thanks Ultra, I know you've tried more than multiple combos of components from your posts.
The biketronics kit is amazing for plug and play and works great at speed. Clean power and sound, just wish for a little more low end. I know most of it gets lost at speed unfortunately.
Bunker
Audio Systems
18
Jul 29, 2016 04:16 PM
CallMeJus
Audio Systems
Jun 4, 2016 10:24 AM
rattracer
Audio Systems
Nov 27, 2014 12:56 PM
user 6292802
Audio Systems
Jul 16, 2014 10:58 AM
FFHD05
Mar 26, 2012 09:32 PM
