I just installed a new set of Moto 602s wile I was tuning my gains with a MM I'm only getting 31 volts at max volume with a 1k -5 test tone does that sound right? I did set gains to 24.5 I also installed a new Sony double din. 2014 ultra limited
That amp will only do 150 watts in 4 channel mode
So 24.5 Vac will be your max setting per channel
How you get to that is a matter of opinion.
But going beyond the 24.5 VAC at anypoint on the system will be taxing the amp all Speaks @4 Ohm
I:E set HU at ž volume and tune to 24.5 VAC (could get into issues if deck ever goes to full volume) like with AVC turned on
