Anyone have a difficult time getting your fairing back on after adding an amp? Installed a J&M amp on top of the Boom tray and now with the wires I’m having a hard time getting the fairing into place. When I take out the tray you can see into the fairing above the glove box (Ultra Limited). Thanks
I’ll bet anything that the OP assembled both tiers of the JM amp tray and as a result, the front end of whatever amp he’s got is pushing up into the fairing on the left and right sides behind the headlight. OP— did you zip off the two little pillars on either side of the amp tray base and throw the top part away? Orrr do you have a half inch space between the radio and the secondary tray that your amp sits on? What amp? Take a pic and throw it up here. Unless you didn’t cut those little metal pillars off. If that’s the case, grind them off and toss the top part of the amp tray and any amp will fit just fine.
Welp I’m a lil smart and there is nothing attached to the bottom of the amp at all. I can see the J&M sticker with manufacture date. Oh and it is pushed completely forward to the gauges against the wiring harness. Its a 2016 Ultra Limited and a J&M 500 watt amp. Usually I go to the old lady to get my ***** busted. Geesh!!!!
I hope to have pics later. Left the stock Harley tray on top of the HU. When I took that off you could see into the fairing area around the glovebox while sitting on the bike.
I am very sorry, but I dont think that big o'l 500w ROKKER is going to fit in there using the stock Harley tray mounted to the top of the radio ,,,,
this is the mounting tray that J&M built for that amp when we mounted them in 2014-2016 Harley StreetGlides and Ultras (prior to the current ROKKER 630w) ,, https://www.jmcorp.com/ProductDetail...tID=JABK-HBW14 ,,,,
two piece laser cut stainless steel ,,,,,, I can get a good VIP discount code for you if you need one ,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Looking at picture amp is right up to wind scoop and is so thick no way going to fit front edges are hitting bad.i have tray he linked you to and still don't know how that big **** amp is going to fit .jm says it will so assume it true or I would never has thought so.hdp4 tight JL 600/6 very tight little trimming needed.let us know how it sounds when you get it figured out.
