Amp recommendation for RG
Old Oct 13, 2017 | 05:19 PM
SBates08's Avatar
SBates08
Originally Posted by Rhino-1
Who makes the B52?
Cerwin Vega.
Old Oct 13, 2017 | 06:02 PM
Mchad's Avatar
Mchad
I have that amp, using the BT LL’s and while I was going to use the Kappa’s, I decided on Polk MM1’s. Couldn’t be happier with this very inexpensive and simple upgrade.
Old Oct 13, 2017 | 06:07 PM
yooperhog's Avatar
yooperhog
Who makes the B52?
cerwin vega. oops. late for supper again...but that amp is small in size, should be able to tuck it in a few spots
Old Oct 13, 2017 | 06:36 PM
Mchad's Avatar
Mchad
I used this bracket for the B52 - some 3m VHB to hold it down. Fit perfectly.
Amazon Amazon
Old Oct 13, 2017 | 08:04 PM
yooperhog's Avatar
yooperhog
good find on the amp mount plate
Old Oct 15, 2017 | 02:55 PM
Rhino-1's Avatar
Rhino-1
Cool. So, in order to wire it into a '16 Street Glide, I would need to buy a mount (Hog Tunes makes aftermarket mounts), upgrade my speakers (probably to Kappa's), tap the signal into the acc power, and then have my HU flashed to flatten-out the internal EQ?
Will the wiring be self evident? Or is there a kit for the Rushmore models that simplifies wiring?
Thanks!
Old Oct 15, 2017 | 03:53 PM
Babyboy's Avatar
Babyboy
Thanks!
No flash is needed if you are only doing a fairing upgrade.
You will need to get a Biketronics BT355 Lineleveler to correct the signal coming out of the head unit.
Depending on the amp you are goikng to use most will fit in the stock amp tray. As noted most.
As for your remote wire HD has a pigtail for the P&A harness under the fairing to use as a remote.
IndyNick
Audio Systems
Jun 20, 2018 01:11 PM
cfave
Audio Systems
Mar 1, 2018 01:06 PM
Jamestheron08
Audio Systems
Dec 11, 2016 04:05 PM
Paul D. Brown
Feb 2, 2014 04:17 PM
Winkokid
Dec 26, 2012 07:23 AM
