Multiple amps
Thinking of getting rid of my hertz hdp4 and running 2 amps. Which 2 would be recommended to run a pair of vo6x9’s and mmats 601.4 and ddb3 horns. Wanted 2 amps that I could bridge at 4 ohms to run around 175-200 or so to my vo’s and sane for my mmats and b3’s. Looking for micro style amps to fit in fairing. Thanks
Thinking of getting rid of my hertz hdp4 and running 2 amps. Which 2 would be recommended to run a pair of vo6x9Â’s and mmats 601.4 and ddb3 horns. Wanted 2 amps that I could bridge at 4 ohms to run around 175-200 or so to my voÂ’s and sane for my mmats and b3Â’s. Looking for micro style amps to fit in fairing. Thanks
You can run 200 to the vo BUT you will be crossing them higher, and 150 is plenty. Get a eq or dsp and you will bring them to where you want. If after that you still feel you don't have enough, then time to evaluate you end game and plan a redesign of the setup.
Maybe, but you won't be crossing them at 70hz, probably closer to 90-100hz.
At this point what do you have to lose? Like Slye said, try it and if you think you need more go from there.
