Installed lower speakers, only get white noise - HELP!
Old Mar 10, 2018 | 12:39 AM
macabra11's Avatar
macabra11
Default Installed lower speakers, only get white noise - HELP!
I have a 2015 Road Glide Special and have been running a Biketronics Bt4180 with just fairing speakers hooked up. When I installed my BT equipment, I hooked up the rear line leveler (BT355) and ran speaker wires for future upgrade.
Well I just got lowers, installed the lower speakers, turned on the bike and there was no music coming from the new lowers. I can hear a faint white noise coming from them, and I even verified this by unplugging/plugging the speaker.
I pulled my fairing apart to check that all connections were solid and was hooked up right. It all looked right to me, and I knew the fairing speakers were working great, so I decided to swap the coax connections on the line levelers. Well then I had sound to the lowers and the white noise to the fairing speaks. I switched it back and buttoned everything up.
Could my LL be busted? Am I missing a step?
Old Mar 10, 2018 | 12:43 AM
SBates08's Avatar
SBates08
You need the flash for an Ultra to activate the rear speakers. 4 speakers (fairing and tourpack) and zero amps is the flash you need.
Old Mar 10, 2018 | 12:46 AM
macabra11's Avatar
macabra11
Well crap. I thought I only needed a flash if I wanted to activate the fader control?
Old Mar 10, 2018 | 12:49 AM
SBates08's Avatar
SBates08
No sir. It's needed to activate the rear speaker outputs as well. Folks that don't do the flash split the signal off the front outputs via Y splitter off of the LL.
Old Mar 10, 2018 | 12:53 AM
macabra11's Avatar
macabra11
So if I get a coax Y splitter (is there a certain type I should be looking for?), will the power output be the same as if I were running two LL's?
Is there any other benefit to paying for a dealer flash?
Oh, and THANK YOU! It's nearly midnight and I bent over my bike all day.
Old Mar 10, 2018 | 12:56 AM
SBates08's Avatar
SBates08
Just a regular Y rca splitter. You'll need 2 of them. You won't be able to tell any difference at all in the sound. You just won't have fade control.
Old Mar 10, 2018 | 08:45 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Just my .02 I would get the head unit flashed for fader control. You never know when you might change something down the road and the front or back may be too loud for your liking. Also in my situation my wife doesn't like the music very loud in the back so I just run the fader towards the front when she rides with me.
Old Mar 10, 2018 | 09:31 AM
travelingypsye's Avatar
travelingypsye
I second that. I will also add if you change speakers in the front upper or lower and run 2 different brands more than likely the sensitivity will be different and one will always sound louder that the other. Yes you can adjust the amp gain to compensate but with different sources of music (mp3, fm, ect) some will sound louder in one channel than the other and if you drop the gain to even them out then you loose max potential for your set up. Just my 1.5 cents worth.
Old Mar 10, 2018 | 10:30 AM
marshallb's Avatar
marshallb
You can "level match" with the gains, if you find that one set of speakers is "overpowering" another. If a flash is very expensive at all I wouldn't spend my money on it.
Old Mar 10, 2018 | 11:37 AM
Hoyt 1911A1
The thing is you usually cannot adjust the gains while riding. What you hear from the front versus the back will change once you get into the wind. I thought I had my setup "gain balanced" sitting in the basement but once I got out on the road found that I had to run the fader quite a bit to the rear to hear those speakers, starving the front of a good signal in the process.
I understand budgets but the reason we are on this journey is because for us "good enough" is never good enough.
