I had read not to mess with adjustments as they are preset. Also I never flashed bike because just amp and 2 speakers shouldn’t need it. If I do adjust LL could I get back to factory settings if need be.
Trying to troubleshoot everything else before I mess with LL. Thanks though
I had read not to mess with adjustments as they are preset. Also I never flashed bike because just amp and 2 speakers shouldnt need it. If I do adjust LL could I get back to factory settings if need be.
Ya I read that too.... its not a big deal to turn them back to stock. Up to you
This sounds a bit beyond my knowledge level but, willing to learn. My set-up is also tinny sounding. 15 Streetglide Sp. with BT amp and (can't remember exact #) AA moto 602 speakers. Clearance checked, all wires perfect! Just a bit too much highs. Agreeing with bzmannn, I was told the same thing. How do you know which way to turn, and by how much?
Just a quick thought, there has been. many times I've read that Mike at BT recommends doing a factory reset after installation. I'd try that before moving the line leveler adjustment.
I guess i just saw it the other way,not to much highs but not enough lows, once i adjusted the BT LL I was able to get the lows back, and then fine tuned the HPF on my amp to my liking. prior to adjusting the LL, the HPF did nothing.
i dont have any adjustments on filter either H L but i did change gains from 31.6vac to 42.3 and sounds pretty good. but i still have clipping goi8ng on at 3/4 volume or above I set speed control at 1 or 2 as i like loud, sorry what is factory reset not read any thing on it. would it matter that i did not flash with the reset
imho 42.3 sounds way too high for that system. Gains that high plus avc will smoke those speakers.
