Rockford Flash
Old Apr 10, 2018 | 09:42 AM
InthewindMN's Avatar
InthewindMN
Default Rockford Flash
Does anyone have experience with the radio flash that Rockford recommends (2 speaker 1 amp)? I have a local Indy with the technoresearch software that can do this flash. Wondering how it compares to the bt355.
Old Apr 10, 2018 | 11:15 AM
travelingypsye's Avatar
travelingypsye
Not sure if that will work. I remember reading past post about the nightmares of flashing to add aftermarket units. Even if the HU is flashed for 1 or 2 amps, it is flashed for HD amps and not aftermarket amps. It might work but I for one don't want to take the chance with my amp in the hands of a HD flash. Now your indy just may be able to do it. Reach out to haze here as he may be able to help you and your indy.
Old Apr 10, 2018 | 12:14 PM
haze324's Avatar
haze324
Yup! We flash every bike we do.
The HD dealers can no longer do the "aftermarket" flashes like the one Rockford recommends. If you Indy has a tool do it, try it. Worse case he flashes it back. Just note once you flash the HU you no longer use a BT line leveler, you need a regular LOC.
Old Apr 10, 2018 | 12:28 PM
InthewindMN
what configuration flash do you use? Is there a option to make the fade function?
Old Apr 10, 2018 | 02:11 PM
marcodarq's Avatar
marcodarq
4 speaker no amp. is the one to try first. i flash them also, with the same tool.
m
Old Apr 10, 2018 | 02:18 PM
InthewindMN
m
Thanks for the info.
Old Apr 11, 2018 | 07:17 AM
InthewindMN
What happens if you run a BT after flash?
Old Apr 11, 2018 | 09:45 AM
travelingypsye
It depends on the flash. If your indy flashes it as the dealer would then you will need the LL after flash to keep it from distorting on the lows and eventually blowing the speakers.
Old Apr 11, 2018 | 08:00 PM
marcodarq's Avatar
marcodarq
There are actual bin files that alter the eq curve coming out of the radio. With the proper file chosen the bt355 is not needed for eq correction. The bt355 serves 2 purposes, it tames the eq curve from the stock radio with the crap book eq output, and converts to a low level rca connection point.
If the correct bin file is chosen, that does NOT use the crap boom eq, any loc can be used or in the case of the Arc PSM, or the RF DSR1, you can go high level in to your dsp and move on from there.
M
Old Apr 11, 2018 | 09:08 PM
InthewindMN
M
It seems like getting that correct bin file is the hard part. I don’t plan on using a dsp at this point if I can get decent sound with a flash. The BT isn’t bad but would like a little better. I already have the BT installed so not sure the effort would be worth the gains. How much better does a flash sound compared to the BT?
Curated Content Editor
Oct 17, 2018 08:41 AM
travelingypsye
Audio Systems
72
Sep 30, 2018 04:37 PM
Wmbailey5
Audio Systems
24
Aug 22, 2018 08:31 AM
rdc401
Audio Systems
May 30, 2018 07:34 PM
travelingypsye
Audio Systems
Jan 16, 2018 04:34 AM
