Speaker Advise
Old Apr 24, 2018 | 07:08 AM
5280Ruffian's Avatar
5280Ruffian
Default Speaker Advise
Good morning - the HK head unit on my bike has been cutting out. Instead of replacing it with the factory unit, I have decided to get the JVC KD-X35MBS head unit. Since I am already in the fairing, I would like to replace the speakers too. I have no idea where to start.
Thoughts:
  1. I am looking to stay between $100-$150
  2. I am not unhappy with the factory speakers, but I would like a bit better clarity and volume.
  3. I have an install kit on the way that allows me to retain the handlebar control.
  4. I ride in the rain, a lot. Weatherproof is important.
What speakers would you recommend, that meets those requirements? I am an audio rookie. I had looked at the Kicker PS5250 but they are 2 ohm, which I read is good for the HK head unit. Does that mean they would not be good on the JVC?
Thanks for the look.
Brandon
Old Apr 24, 2018 | 07:29 AM
travelingypsye's Avatar
travelingypsye
If you have the 2008 SG in your sig, you will need speaker adaptors for 5.25 to 6.5. These will work.
https://www.amazon.com/Metra-82-9601-Speaker-1998-2013-Davidson/dp/B00JKXSJTM/ref=sr_1_1?s=automotive&ie=UTF8&qid=1524572590&sr=1-1&keywords=speaker+adapters+harley&dpID=41e5eyjciUL&preST=_SY300_QL70_&dpSrc=srch https://www.amazon.com/Metra-82-9601-Speaker-1998-2013-Davidson/dp/B00JKXSJTM/ref=sr_1_1?s=automotive&ie=UTF8&qid=1524572590&sr=1-1&keywords=speaker+adapters+harley&dpID=41e5eyjciUL&preST=_SY300_QL70_&dpSrc=srch
Also you can upgrade your speaker only but still loose out on great sounds without an amp. I strongly suggest getting an amp for any speaker set up on a bike.
This set up will do you justice. The amp and the speakers at the bottom.
https://www.amazon.com/Cerwin-Vega-B52-Stealth-Bomber-Channels/dp/B00ZAQVMJC/ref=sr_1_1?s=automotive&ie=UTF8&qid=1524572802&sr=1-1&keywords=cerwin+vega+b52 https://www.amazon.com/Cerwin-Vega-B52-Stealth-Bomber-Channels/dp/B00ZAQVMJC/ref=sr_1_1?s=automotive&ie=UTF8&qid=1524572802&sr=1-1&keywords=cerwin+vega+b52
BTW those kappas on the bottom at that page are a good budget upgrade speaker.
Old Apr 24, 2018 | 07:46 AM
BlackPearl#1's Avatar
BlackPearl#1
Like TG says. There a million treads about speakers only, not one you will find is a successful upgrade, only because your factory head unit is only capable of producing so much power, and it simply is not enough. Links above are tried and true, proven result parts.
Kris
Old Apr 24, 2018 | 07:50 AM
5280Ruffian
Ignorant, new guy question: does the larger speaker sit farther in the fairing or mount outside the fairing?
If if I decided to get the amp, what mounting would I need?
if yo can point me towards a thread, I’d be more than happy to read. I don’t know what to search to get good results. “Amp” or “speakers” bring up a lot of not useful in this case threads.
Old Apr 24, 2018 | 07:59 AM
travelingypsye
Those adaptors allow the 6.5 speakers to fit inside the fairing just deeper inside. You can mount that amp right on top of the radio using double sided Velcro and zip ties. easy peasy.
Old Apr 24, 2018 | 08:00 AM
5280Ruffian
Awesome! Thanks! I will research those links when I’m home.
Old Apr 24, 2018 | 08:02 AM
travelingypsye
Awesome! Thanks! I will tease arch those links when I’m home.
You wont be disappointed with that setup.
Old Apr 24, 2018 | 09:57 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
OK now who is going to pony up and tell him he needs a set of lowers and an SS PN4.1000d?
Old Apr 24, 2018 | 09:59 AM
5280Ruffian
I have lowers. Trying to avoid the urge to get lower speakers and pods... hoping to add them later. But not now.
Old Apr 24, 2018 | 10:15 AM
Juice's Avatar
Juice
1. If you plan on lowers later I would get a 4 channel amp now that you can grow into.
2. what control module did you decide so you can keep your thumb controls?
