Loss of signal or other issue with Deutsch Connectors?
I'm thinking now about making a quick dis-connect set up for the wires going to my saddlebag lids. the speaker wires are 16 awg and i was thinking of making up a couple of 4 pin connectors.2 for the 6x9 and 2 for the horn on the bridge. has anyone run into any kind of issue with that connector set up? i'm curious because the pins and sockets are kinda on the small size, but that style of connector is easy for me to get and easy to work with for me. i was just wondering if anyone had run into any loss of signal strength of sound quality, anyone???
thanks
marco
thanks
marco
Where did you mount your crossovers? You should only need a single 2 pin connection going straight to your crossover. That is, if you've mounted the crossovers under your lids. I have coaxial speakers, so I could be wrong, as my crossovers are built into the speakers themselves. I do not notice a degradation of sound, by the use of my deutsch connectors. I used these:
Bafflingbs (05-16-2018)
The Arc PSM is an ACTIVE crossover, among many things. the crossover point for the 6x9 is nowhere close to the DD-VO B3 horn, I'm sending 150-190 watts to the 6x9 (once i get my amp selection pinned down). way to much for the horn it this scheme. the horn is actually wired on a circuit for the 6.5 in the tp pod, which is only getting between 70 and 100 watts, not finalized on that either.. the different power and crossover requirements require the use of more wires. they tuck away nicely when assembled, just wanting to make a connector so the bags can be easily removed for service repair work.
m
m
I used these for a quick disconnect of my DD VO 6X9s in my saddlebags. I wired them with 14awg wire. I have not experienced any loss in signal or other issues.
