2017 sgs install help
Old Jun 3, 2018 | 06:39 AM
ColoradoLG's Avatar
ColoradoLG
Default 2017 sgs install help
Coming from the land of Dyna's to Baggers...
This is my list of items to buy (planning on replacing fairing speakers, installing amp, and adding speakers to my lowers), and any help you guys can give would be great:
Two sets of these speakers:
https://www.amazon.com/dp/B072Q8BNV5/?coliid=I1MNX12AD7DWPA&colid=YWA11VK9FQ9H&psc=0&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B072Q8BNV5/?coliid=I1MNX12AD7DWPA&colid=YWA11VK9FQ9H&psc=0&ref_=lv_ov_lig_dp_it
This amp:
https://www.amazon.com/dp/B00ZAQVNX2/?coliid=I32DDGORN9T35T&colid=YWA11VK9FQ9H&psc=0&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B00ZAQVNX2/?coliid=I32DDGORN9T35T&colid=YWA11VK9FQ9H&psc=0&ref_=lv_ov_lig_dp_it
Install Kit:
https://www.amazon.com/dp/B01MR5EN67/?coliid=I6V3VQ6E6JQR5&colid=YWA11VK9FQ9H&psc=0&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B01MR5EN67/?coliid=I6V3VQ6E6JQR5&colid=YWA11VK9FQ9H&psc=0&ref_=lv_ov_lig_dp_it
Biketronics Line Leveler: http://www.biketronics.com/bt355-hd-...r-2014-and-up/
RCA M/M plugs:
https://www.amazon.com/Monoprice-1-5ft-Premium-22AWG-Cable/dp/B003L1717K/ref=sr_1_3?ie=UTF8&qid=1528025879&sr=8-3&keywords=rca+1.5+ft&dpID=416iQd-rgoL&preST=_SX300_QL70_&dpSrc=srch https://www.amazon.com/Monoprice-1-5ft-Premium-22AWG-Cable/dp/B003L1717K/ref=sr_1_3?ie=UTF8&qid=1528025879&sr=8-3&keywords=rca+1.5+ft&dpID=416iQd-rgoL&preST=_SX300_QL70_&dpSrc=srch
One question I have is should I run my lowers parallel(??) with the fairing speaker, or run the off the rear of the amp. If I run them off of the rear, do I need another bt355 and a flash??Any and all help is appreciated.
Old Jun 3, 2018 | 07:03 AM
Tailwind's Avatar
Tailwind
You might rethink the amp strategy. A bit light on watts for 4 Speaks at 4 ohm.
Regarding the flash - fade question, it's up to you. If u want the ability to fade or valence the sound out on the fly then u will need another BT355 and a HD Flash for 4 Speaks.
If not, you can just set the amp gains to provide for such balance but ur gonna have to pop the hood a few times to get it all dialed in after some rides.
T.
Old Jun 3, 2018 | 07:07 AM
ColoradoLG's Avatar
ColoradoLG
Do you have any suggestions on a different amp, or do you think I should rethink the speakers? I know it's ultimately up to me, but this is foreign territory for me.
I really don't mind reassessing a few times after rides. Thank you for that advice.
Old Jun 3, 2018 | 07:10 AM
travelingypsye's Avatar
travelingypsye
That amp wont be enough to run 4 speakers as it is 80w x4. A pn4.1000d will do those justice. This will do it.
https://www.amazon.com/Soundstream-PN4-1000D-4-Channel-Picasso-Amplifier/dp/B00VH40878/ref=sr_1_1?s=electronics&ie=UTF8&qid=1528027522&sr=1-1&keywords=pn4.1000d https://www.amazon.com/Soundstream-PN4-1000D-4-Channel-Picasso-Amplifier/dp/B00VH40878/ref=sr_1_1?s=electronics&ie=UTF8&qid=1528027522&sr=1-1&keywords=pn4.1000d
Im not sure of those rca cables either. These are what I use as do others.
https://www.sonicelectronix.com/item...r-SI421.5.html
If you get a good 4 channel amp, you can run it straight and not have to bridge it or run parallel on the speakers.
Old Jun 3, 2018 | 07:17 AM
ColoradoLG's Avatar
ColoradoLG
https://www.amazon.com/Soundstream-PN4-1000D-4-Channel-Picasso-Amplifier/dp/B00VH40878/ref=sr_1_1?s=electronics&ie=UTF8&qid=1528027522&sr =1-1&keywords=pn4.1000d
Is this the same
https://www.amazon.com/Stinger-SI421-5-Foot-2-Channel-Interconnect/dp/B005F1PJ1Y/ref=sr_1_1?s=electronics&ie=UTF8&qid=1528027951&sr=1-1&keywords=Stinger+SI421.5&dpID=51IE70cpteL&preST=_SY300_QL70_&dpSrc=srch https://www.amazon.com/Stinger-SI421-5-Foot-2-Channel-Interconnect/dp/B005F1PJ1Y/ref=sr_1_1?s=electronics&ie=UTF8&qid=1528027951&sr=1-1&keywords=Stinger+SI421.5&dpID=51IE70cpteL&preST=_SY300_QL70_&dpSrc=srch
I know it's cheaper on the other site, but I just like to order it all from the same place if possible. Makes tracking it all easier. And thanks for the amp advice. I'll most likely go with that Soundstream.
Old Jun 3, 2018 | 07:49 AM
Babyboy's Avatar
Babyboy
Using the PN4 1000D on the stock amp tray in the Rushmore batwing is a bit on the challenging side but it will fit with some patience and some fanasing.
If you dont want the headaches of getting the amp to fit on the stock amp tray you can get an aftermarket tray from JM Corp. For around $160. The part number for the tray is JABK-HBW14
Old Jun 3, 2018 | 07:50 AM
travelingypsye
Originally Posted by ColoradoLG
Is this the same https://www.amazon.com/Stinger-SI421...70_&dpSrc=srch ?
Yup as long as they are male to male connectors, they will work.
Old Jun 3, 2018 | 09:52 AM
Tailwind's Avatar
Tailwind
How much u want to spend on an amp after all the other goodies are accounted for?
T
Old Jun 4, 2018 | 01:02 AM
ColoradoLG's Avatar
ColoradoLG
T
Guess I'd like to keep it under $300 for the amp. As I said...I'm open to all suggestions. TIA
kevinm
Audio Systems
Apr 27, 2019 07:21 PM
AGFazio
Audio Systems
Mar 3, 2016 05:45 AM
2007z71
Audio Systems
Mar 29, 2015 10:53 AM
nivensid
Jun 7, 2012 11:21 PM
pit1600
Feb 26, 2012 07:25 AM
