Tuning Mosconi D2 100.4 with/without BT355
I have a 2015 RGS with Boom 6.5, just like many other folks here, I found that the Boom system is just another shix sound sytem that Harley shoved down our throat. I bought Focal ES 165 KX2 2 ways components, Mosconi D2 100.4 amp and BT355 LL, going to run Bi-Amp on the components through the Focal Bi-Amp compatible passive crossover driven by all 4 channels from the amp. The question is how should I run my amp with what I have? I was considering the following:
- Stock HU, Stock Flash (no amp-2 spkrs), BT355LL, use low level input on the Mosconi amp, set the amp output at full range and let the passive crossover do its job.
- Stock HU, Stock Flash (no amp-2 spkrs), BT355LL, use low level input on the Mosconi amp, set the amp crossover at High Pass and tune while still leaving the passive crossover intact.
- Stock HU, 2 amp 8 speakers flash, NO BT355LL, use high level input on the Mosconi amp, set the amp crossover at full range and let the passive crossover do its job.
- Stock HU, 2 amp 8 speakers flash, NO BT355LL, use high level input on the Mosconi amo, set the crossover at High Pass and tune while still leaving the passive crossover intact.
Thanks in advance for the advices folks!! 👍
