Southern Engineering strikes again
Old Oct 11, 2018 | 02:33 PM
ssmorga78's Avatar
ssmorga78
Originally Posted by Hoyt 1911A1
ssmorga my head unit is the stock HK with preamps installed by Iron Cross Audio. It puts out a little lower voltage on the low level outputs than most aftermarket head units do, so I suspect that is the difference. If I remember correctly with a 1Khz test tone I can turn the head unit up to one notch from wide open before I get clipping. Some head units will go wide open with no clipping. The 2/3 volume recommendation is really not applicable if you can test properly. It is just a setting some folks use if they do not have access to an oscilloscope. I had a similar discussion with Iron Cross a while back. Each head unit is different so there is no one size fits all volume setting when tweaking gains.
Maybe put the scope on the output of your phone to see what your peak to peak voltage is with a 1 KHz test tone. If it is down around 4 volts or so maybe the LD-10 would be worth a try. It boosted the 4v output of my stock head unit to almost 9v peak to peak with no clipping at all. If I turned the adjustments of the LD-10 higher the voltage didn't increase but the wave form definitely clipped. I was definitely pleased with the increased volume from my rear speakers after taking the time to set the LD-10 properly.
Did that, and if I remember correctly... it was right around 1.2v-1.5v.
Old Oct 11, 2018 | 02:52 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Wow that seems pretty low compared to most head units I have seen the specs for. As cheap as those LD-10s are it might be worth tinkering with.
Old Oct 11, 2018 | 02:56 PM
ssmorga78's Avatar
ssmorga78
Yeah, I thought so as well.... but I found a good deal on a DSR1($200 new) so I have one on the way that should be here Monday.
0lowrider1
Audio Systems
Aug 8, 2016 02:56 PM
Az-Riding
Audio Systems
22
Aug 15, 2014 07:42 AM
HDogg
Audio Systems
Oct 3, 2013 06:53 AM
booch
Audio Systems
Mar 13, 2013 10:46 AM
dbuff
May 12, 2008 11:39 AM
